Sine Isochronic Modulator Plugin
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Permanent link to this post Posted by GendeDios » Tue Oct 05, 2010 3:15 am
From this topic:
viewtopic.php?f=39&t=39723
I've taken this code's piece from this post:
stevethefiddle wrote:Here's some code that will produce a wavetable with a 50% sine pulse.
Note that unlike the other wavetables this one is all in the positive half of the waveform, so you don't need
Code: Select all
(mult 0.5 (sum 1.0 ..... ))
in the "sweep" function.
Code: Select all
(setq duration 0.5)
(abs-env
   (progn
   ;; half sine wave
   ;(setq si (abs-env (osc (hz-to-step 1.0) duration *sine-table* 0)))
   ;; full sine wave
   (setq si (mult 0.5 (sum 1 (osc (hz-to-step 2.0) duration *sine-table* 270))))
   ;; add silence
   (setq pulse (sim si (s-rest 1)))
   ;; create wavetable
   (setq *waveform* (list pulse (hz-to-step 1) T))))
; test it
;(osc 69 1 *waveform*)
(mult s (fmlfo (pwlv 20 1.0 10) *waveform*))
I added a few things and the end was this.
Thanks to Steve for the code.
sinisomod.ny
(1.26 KiB) Downloaded 355 times
GendeDios
Re: Sine Isochronic Modulator Plugin
Permanent link to this post Posted by magnelectro » Sun Feb 06, 2011 8:05 pm
Thanks for this!
magnelectro
Return to New Plug-Ins
Who is online
Users browsing this forum: No registered users and 3 guests
