Envelope follower / ducker
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Re: Envelope follower / ducker
Permanent link to this post Posted by steve » Thu Oct 26, 2017 8:21 am
Trebor wrote:If repeat effect, ("Ctrl"+"R"), is used to repeatedly apply version-2 of dynamic-mirror to one track only, the effect being applied will be different with each repetition, because the control-track is changing, (not necessarily a bad thing, but perhaps counter-intuitive).
I can see how that might look a bit strange, but it does what it says and "repeats the effect" (the "effect" is to follow the amplitude envelope and then apply that as a gain curve).
If you don't want that, then (as you're aware trebor), you can use a duplicate track as the "control track".
Also, we don't really want to be retaining the envelope in RAM after the plug-in has finished as it could be quite large.
Trebor wrote:Plus, with the original track present, there is the opportunity to mix to dilute the effect on the processed track.
That's a good trick :)
Permanent link to this post Posted by Trebor » Fri Oct 27, 2017 6:03 am
Reverb reduction ...
reverb-reduction with dynamic-mirror.gif (126.49 KiB) Viewed 310 times
Trebor
Permanent link to this post Posted by Trebor » Fri Oct 27, 2017 6:04 am
steve wrote:... Feel free to write some documentation if you have time ...
Dynamics Processing
Dynamic Mirror
(dynamic-mirror.ny) download
Author: Steve Dalton
Is an envelope-follower : it applies the loudness-envelope of one track to the selected track(s) below it.
It can also apply the inverted version of the envelope of the control track to other track(s) below when in ducking mode, (so is a possible alternative to AutoDuck).
When only one track is selected Dynamic-Mirror will re-apply its envelope to itself, (or its inverse when in ducking mode). Applying in "mirror" mode, (i.e. envelope-follower mode), to self, causes dynamic-range-expansion. Applying to self in ducking-mode causes dynamic-range-compression.
Trebor
Permanent link to this post Posted by Trebor » Wed Nov 01, 2017 1:22 am
If used on stereo-tracks, Dynamic mirror uses an average of the two track's envelopes.
So for some applications* you will need to apply it to separately to each stereo track,
(* e.g. if you want a flat envelope ).
Trebor
Permanent link to this post Posted by steve » Wed Nov 01, 2017 1:41 am
Trebor wrote:If used on stereo-tracks, Dynamic mirror uses an average of the two track's envelopes.
however, applying different envelopes to a stereo track can cause a strange panning effect.
Previous
Return to Nyquist
Who is online
Users browsing this forum: No registered users and 4 guests
