Chimes overtones delay
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Permanent link to this post Posted by Giovani » Fri Sep 15, 2017 9:50 am
I have tried a chimes delay. I love randomness and also, every notes in my examples are tuned to pentatonic scale. But, I have also one idea.
What do You say to create chimes overtone delay, which is based on speed multiplies of your recording. Or, something is just exists here?
Thank You.
Re: Chimes overtones delay
Permanent link to this post Posted by steve » Wed Oct 04, 2017 3:08 pm
You can make pitch shifting delays with Nyquist. For example, this code in the Nyquist Prompt effect:
Code: Select all
(simrep (i 30)
  (let* ((offset (* i 0.1))
         (ratio (+ 1.0 (/ i 20.0)))
         (decay (/ ratio)))
    (at-abs offset
      (cue  (force-srate *sound-srate*
              (stretch-abs ratio
                (sound (mult decay *track*))))))))
when applied to a mono sound, produces this type of effect:
(77.28 KiB) Downloaded 16 times
The "Delay" effect also has some pitch shifting ability:
Return to Nyquist
Who is online
