Slide effect - HELP NEEDED
Archive of Nyquist Plug-ins.
Many of the plug-ins here will be available on the Audacity Wiki.
This Forum is an archive of old topics concerning Nyquist plug-ins.
Feedback and questions relating to topics may be posted, but please
DO NOT POST NEW TOPICS HERE.
New plug-ins may be posted on the New Plug-Ins board.
Other posts relating to Nyquist should be posted to the main Nyquist board.
The main repository for Audacity/Nyquist Plug-ins is on the Audacity Wiki.
Re: Slide effect - HELP NEEDED
Permanent link to this post Posted by Michael Kazmierski » Fri Jul 07, 2017 12:20 am
Well, the only reason why I don't ever want to try 2.1.2 is because it makes no sense at all for a plugin to insert unwanted silence and latency which might not be corrected, plus I'm not used to having effects perform in real-time. When I replaced *track* with just S, it doesn't work.
Michael Kazmierski
Operating System: Windows 7
Permanent link to this post Posted by steve » Fri Jul 07, 2017 12:24 am
Michael Kazmierski wrote: it makes no sense at all for a plugin to insert unwanted silence and latency which might not be corrected
What are you referring to?
Permanent link to this post Posted by Michael Kazmierski » Fri Jul 07, 2017 12:27 am
I can remember for some reason, whichever plugins that can be changed in real-time when you play a file, I remember something about the effect having to insert latency so it could be applied. I'm not sure if this is still true in 2.1.2, but to me it just doesn't make sense.
All I did with the code was to change *track&* to S, and version 4 to version 3. The plugin appears, but when I run it, it says Nyquist did not return audio.
Michael Kazmierski
Permanent link to this post Posted by steve » Fri Jul 07, 2017 1:07 am
Michael Kazmierski wrote: remember something about the effect having to insert latency so it could be applied.
The bug that you are referring to affects the preview of some third party plug-ins. It does not affect how the effect is applied, and does not affect any of the effects that are shipped with Audacity. It also does not affect Nyquist effects.
Permanent link to this post Posted by steve » Fri Jul 07, 2017 1:36 am
Michael Kazmierski wrote:The plugin appears, but when I run it, it says Nyquist did not return audio.
Try running the effect using the Debug button rather than the OK button.
What does it say in the debug window?
Permanent link to this post Posted by steve » Thu Oct 12, 2017 1:34 pm
The "Sliding Speed Change" plug-in is now available on the Audacity wiki: http://wiki.audacityteam.org/wiki/Nyqui ... eed_Change
Previous
Return to Plug-in Archive
Who is online
