returning SOUND to outer DOLIST loop?
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Permanent link to this post Posted by dmonty » Sat Mar 11, 2017 6:39 pm
I'm new to nyquist/lisp. Having trouble returning a SOUND object inside a DOLIST loop.
The dolist loop on line 28 returns NIL. I need the SOUNDs generated inside the loop on line 68 to be appended together outside the loop.
https://github.com/dmonty2/audacity-pem ... mf-list.ny
End goal is to have the user enter a list of frequencies [email protected]:time1,[email protected]:time2... audacity will output a seqence of wav1,wav2,...
Thanks.
dmonty
Re: returning SOUND to outer DOLIST loop?
Permanent link to this post Posted by steve » Sun Mar 12, 2017 9:21 pm
Example 1
Code: Select all
(setf mylist (list 'a 'b 'c 'd))
(setf num 4)
(print
  (dolist (x mylist)
    (print x)
    (dotimes (i num)
      (setf i (1+ i)))))
prints:
Code: Select all
A
B
C
D
NIL
Note that "NIL" is the return value of the 'dolist'
Example 2
Code: Select all
(setf num 4)
(print
  (dolist (x mylist j)
    (print x)
    (dotimes (j num)
      (setf j (1+ j)))))
Error.
'j' is local to 'dotimes', so as the return value of dolist it is unbound.
Example 3
Code: Select all
(setf num 4)
(print
  (let ((count 0))
    (dolist (x mylist count)
      (print x)
      (dotimes (j num)
        (setf count (1+ count))))))
prints:
Code: Select all
A
B
C
D
16
Note that "count = 16" is the return value of the 'dolist'
See also: http://www.audacity-forum.de/download/e ... ef-095.htm
Does that help?
Permanent link to this post Posted by dmonty » Mon Mar 13, 2017 6:58 am
Thanks. The script is now working.
dmonty
Return to Nyquist
Who is online
Users browsing this forum: No registered users and 2 guests
