Nyquist can read and write files, so perhaps you could achieve what you want by reading/writing a configuration file for your plug-in?
Yes I'd like to know how to read/create configuration presets. I can see settings stored in .audacity-data/pluginsettings.cfg but I'm not sure how to pre-seed it?
End goal is to have a PEMF frequency generator with a pick-list (e.g. below). Pick a set of frequencies then give end users the ability to adjust the frequencies - hence my inquiry for presets. I'd like to generate the Frequencies in Audacity because it is cross platform and allows me to playback a frequency and record the end result from the magnet in the same interface.
Abdominal_inflammation - 2720, 2489, 2170, 2000, 1865, 1800, 1600, 1550, 880, 832, 802, 787, 776, 727, 660, 465, 450, 444, 440, 428, 380, 250, 146, 125, 95, 72, 20, 1.2
Abdominal_pain - 10000, 3000, 95, 3
Abscesses - 2720, 2170, 1865, 1550, 880, 802, 787, 727, 500, 444, 190
Abscesses_1 - 2720, 2170, 1865, 1550, 880, 802, 787, 760, 727, 690, 660, 500, 465, 450, 444, 428, 190
Abscesses_secondary - 1550, 802, 760, 660, 465, 450, 444, 428
Acidosis - 10000, 880, 802, 787, 776, 727, 146, 20
Acne - 2720, 2170, 1800, 1600, 1550, 1552, 1500, 802, 880, 778, 787, 760, 741, 727, 660, 564, 465, 450, 444, 428
Aconite - 3347, 5611, 2791
http://www.electroherbalism.com/Bioelec ... s/CAFL.htmThanks.
