Customizable/Combined Delay + Volume + Panning Effect
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Re: Customizable/Combined Delay + Volume + Panning Effect
Permanent link to this post Posted by steve » Fri Mar 06, 2015 1:09 am
Steve Bender wrote:Okay, so Nyquist differentiates between the two. But how do I? I only have one way to input a 3, AFAIK.
If you use a slider widget in the form:
Code: Select all
;control variable ""text-left" int "text-right" <default> <min> <max>
Note the "int". That means that the variable value will be an integer (whole number).
Code: Select all
;control variable ""text-left" float "text-right" <default> <min> <max>
Note the "float". That means that the variable value will be floating point number (fractional number).
If you use a text input widget in the form:
Code: Select all
 ;control variable-name "text-left" string "text-right" "default-string"
Note the "string". That means that the variable value will be a string ("text").
Fortunately we are able to convert between a text "3" and an integer "3" and a fractional "3.0" (in any direction). We'll come to that later ;)
Steve Bender wrote: Is it possible to have the first delay start at 750 ms, but then “cut it” at 1 sec? And if we were to “cut it” before it runs its full 500 ms, I’m assuming it could potentially end at a non-zero crossing, thus causing that “crackle.”
Baby steps. Let's not run before walking :D
If necessary we can apply fade in / fade out to avoid crackles (much faster processing than looking for zero crossing points).
Permanent link to this post Posted by Steve Bender » Fri Mar 06, 2015 4:05 pm
steve wrote:Baby steps. Let's not run before walking.
I know. I just want to know if it’s possible, in theory. Because that would be awesome, and it would help keep me motivated.
I did not have time to do any of this stuff last night. Hopefully this weekend.
Steve Bender
Permanent link to this post Posted by steve » Fri Mar 06, 2015 4:27 pm
Steve Bender wrote:I just want to know if it’s possible,
Probably :D
Let's see how far we get.
Steve Bender wrote:I did not have time to do any of this stuff last night. Hopefully this weekend.
No worries, I'm not in a rush.
Previous
Return to Nyquist
Who is online
Users browsing this forum: No registered users and 7 guests
