Is it possible for someone to tell me what code I’d need to make a set of GLITS tones for broadcast audio as I’m sure there’s a way it can be done more easily using Nyquist code.
The spec is located herehttp://en.wikipedia.org/wiki/Glits
Sorry about the delay replying - I’ve only just spotted this post.
First you will need to make a stereo track (Tracks menu > Add new > Stereo track)
Then make a selection the length that you want the GLITS tones to be.
Then use the Nyquist Prompt effect with this code:
