REQ: R1 MF ("Blue box") Tone Generator
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Re: REQ: R1 MF ("Blue box") Tone Generator
Permanent link to this post Posted by steve » Tue Nov 21, 2017 12:30 am
mharriger wrote:It was a struggle to keep the parens matched up, good indentation seems like it would help.
Yes, good indentation does help, and it makes the code much easier to read. If you are not already doing so, I'd highly recommend using a text editor that has parentheses matching. On Windows, NotePad++ is good. On Linux I use Scite. On Mac, I don't know. NotePad++ and Scite also have syntax highlighting for LISP, which although not quite the same as Nyquist, has enough in common to be useful.
Here's a screenshot of some Nyquist code in Scite text editor. Note the red ")" indicating that it is mismatched, and the color of (some) keywords, quoted strings and comments:
Previous
Return to Nyquist
Who is online
Users browsing this forum: No registered users and 2 guests
