New plug-in effect - PopMute
Archive of Nyquist Plug-ins.
Many of the plug-ins here will be available on the Audacity Wiki.
This Forum is an archive of old topics concerning Nyquist plug-ins.
Feedback and questions relating to topics may be posted, but please
DO NOT POST NEW TOPICS HERE.
New plug-ins may be posted on the New Plug-Ins board.
Other posts relating to Nyquist should be posted to the main Nyquist board.
The main repository for Audacity/Nyquist Plug-ins is on the Audacity Wiki.
Permanent link to this post Posted by steve » Tue Jan 11, 2011 2:01 am
This is currently an experimental effect.
It does not contain any error checking for invalid input and may have bugs.
The effect is like an upside-down Noise Gate.
The effect can heavily attenuate loud sounds. It may be useful for rescuing recordings that suffer from loud clicks or pops.
Downloads:
version 0.2 (obsolete)
version 0.1 (obsolete)
Current Version
I'm not sure if the "link stereo channels" setting in v.01 is worthwhile as I'd imagine that in most cases it would be preferable to process channels independently.
Comments welcome.
[Update: decided that linking stereo channels was not useful, so removed in final version]
Reason: Links updated
Senior Forum Staff
PopMute Before and After
Permanent link to this post Posted by kozikowski » Tue Jan 11, 2011 6:21 am
Remember this? Heavy suppression of the pops without affecting the rest of the performance at all.
rap_without.wav
(767.61 KiB) Downloaded 274 times
rap_with_correction.wav
(767.61 KiB) Downloaded 242 times
Re: PopMute Before and After
Permanent link to this post Posted by Gale Andrews » Tue Jan 11, 2011 6:55 am
kozikowski wrote:Remember this? Heavy suppression of the pops without affecting the rest of the performance at all.
Is this something to do with a feature in Audacity that no longer works?
Permanent link to this post Posted by kozikowski » Tue Jan 11, 2011 6:12 pm
No. It's a new tool that Steve wrote. First "in the wild" application.
Permanent link to this post Posted by steve » Tue Jan 11, 2011 11:00 pm
This was the "in-the-wild" example: viewtopic.php?f=28&t=49854
Koz has asked previously if there could be a "reverse" of my Noise Gate plug-in for muting pops and raised the question again in that thread.
Finally got round to making it: viewtopic.php?f=39&t=50671
Senior Forum Staff
Permanent link to this post Posted by kozikowski » Wed Jan 12, 2011 1:31 am
I like that the "skirts" of the active segment can be tuned so not only the plosive blast goes away, but the slight click before and after as well. That example is far from what I can do with more effort. You can still hear I didn't get the delays quite right.
Given that there is no valuable work at all during the pop, gracefully suppressing them without damaging anything else is a good thing -- and I didn't drill them down to nothing, either. They're just a lot lower than they were and probably a handful of dB down from the overall show volume. They sound like the performer is too close to the microphone, but the pops don't shatter glass any more.
Re: New plug-in effect - PopMute
Permanent link to this post Posted by Irish » Wed Jan 12, 2011 4:03 pm
Looks promising.
I'll play with it a bit and let you know how I get on. I've a very badly damaged copy of Neil Young's "Harvest" (damaged before I got it, I hasten to add) which should make a good test bed.
However, one problem I can see with a record as badly damaged as this, is that there are places where I'm left with gaps where the pops used to be, which is nearly as bad. What about looking at the audio level for, say, 10ms either side of the pop, and setting the attenuation to that level?
POL
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
Irish
Forum Crew
Permanent link to this post Posted by steve » Wed Jan 12, 2011 6:03 pm
Irish wrote:What about looking at the audio level for, say, 10ms either side of the pop, and setting the attenuation to that level?
If the effect is being used on one pop at a time, that relatively easy to do.
If you mean that you want to be able to process multiple pops with a dynamically changing mute level that follows the dynamics of the music, that is quite a bit harder, and I expect that it would also require the threshold level to also change dynamically.
This is not a "clever" effect, it just blindly attenuates sounds that are above the threshold down to a "floor" level. I'll have a look to see if I can make it a bit more intelligent without it becoming horrendously complex.
Senior Forum Staff
Permanent link to this post Posted by DickN » Sun Jan 16, 2011 1:56 am
Pop Mute is a real time saver. I record church services for CD and podcast, and we have a couple of people who can't remember not to clap in front of a mic. I fade out the mic, but not before I've got a string of spikes in the recording. With this tool I can squash the whole string in one operation instead of manually fiddling with each one. It even works on coughs. Just one simple improvement to suggest: Separate settings for attack and decay. I use a ceiling mic to pick up individuals in the congregation speaking without a mic. Sometimes a cough reverberates, so it has a sharp attack and a slow decay. The separate controls would let me approximate the event envelope.
DickN
Permanent link to this post Posted by steve » Sun Jan 16, 2011 7:21 pm
Thanks for the feedback Koz and DickN.
(Topic merged with original "PopMute" topic)
DickN wrote:Just one simple improvement to suggest: Separate settings for attack and decay.
There's always a balance to be drawn with this type of plug-in between flexibility and simplicity. As the complexity of the interface goes up, the usability goes down (especially for casual or novice users). My aim was to make this plug-in as simple as possible to use.
DickN wrote:I use a ceiling mic to pick up individuals in the congregation speaking without a mic. Sometimes a cough reverberates, so it has a sharp attack and a slow decay. The separate controls would let me approximate the event envelope.
That's a persuasive argument for adding one more slider.
There's been no comments regarding the "Linked Stereo" mode, so I'm guessing that it's not really useful.
I've removed the "Linked Stereo" option in this version, though it can easily be re-enabled (open popmute.ny in a text editor and read the comment text near the top of the file).
popmute.ny
Pop Mute version 0.2
(1.84 KiB) Downloaded 555 times
Senior Forum Staff
Next
Return to Plug-in Archive
Who is online
Users browsing this forum: No registered users and 0 guests
