78rpm EQ Curve Generator
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Permanent link to this post Posted by Irish » Sat Jul 10, 2010 11:05 pm
This plug-in arose from the 'Adding Features to Audacity' section of the forum.
For the background, see http://forum.audacityteam.org/viewtopic.php?f=20&t=33824&start=0
The Equaliser effect in the latest Audacity nightly builds http://wiki.audacityteam.org/index.php?title=Nightly_Builds, has a feature which allows EQ curves to be imported or exported as xml files. This raises the possibility that the EQ curves for playback of 78rpm records could be made available as presets in the Equaliser. However the number of EQ curves which exist for 78's (each record label had its own EQ curve) made inputting them a huge task, so I decided to see if it could be automated; hence the plug-in.
This wiki page http://wiki.audacityteam.org/wiki/78rpm_playback_curves gives a long list of 78 EQ curves.
The EQ Curve Generator creates the EQ curve from the given parameters, and writes it to a file in a format that can be read by Audacity's Equalisation effect.
How it Works
All 78rpm EQ curves are defined by two parameters; a Bass Turnover Frequency and a 10kHz Rolloff value. These two parameters define a bass boost curve with a 'corner frequency' or 3dB frequency at the Bass Turnover point, and a treble cut curve which reduces the gain above a certain frequency, so that the gain at 10kHz is at the required value.
(Note that some 78 EQ curves have a 10kHz Rolloff of zero, i.e. they are flat at treble frequencies)
The principal inputs to the plug-in are the Bass Turnover and 10kHz Rolloff parameters and, from them, the bass boost and treble cut filter curves are calculated and summed. Inevitably, the curves overlap to some extent, which gives incorrect results at the two defined points, so a second pass re-calculates the curves to take account of the interaction between them, and produces the combined curve.
Now, the 78rpm EQ curves, according to their definition, have a bass response which increases without any limit as the frequency gets lower, so that sub-sonic frequencies, turntable rumble etc. would be greatly amplified. To avoid this, I have introduced a Bass Shelving component to the curve. This flattens the curve below a selected frequency. The default setting is 50Hz, but it can be changed as required. I should point out that the only basis I have for this addition is common sense and a gut feeling (plus the fact that it is explicitly included as a component in the RIAA curve which replaced the multiplicity of EQ curves in the 1950's), so if anyone can point me to some factual information on this element, I would be grateful.
As an option, I have included the ability to normalise the curve to 0dB at 1kHz.
Once the curve is calculated the values are displayed on screen, and written to an xml file called 78EQCurves.xml in a directory chosen in the initial input window (default is /Program Files/Audacity). The name to be given to the curve is also typed in the input window, and is included in the xml file. (Note that, as the plug-in is currently written, each time it is run, the 78EQCurves.xml file gets over-written with the new curve data.)
Once the xml file has been written, the data can be imported from it into the Equaliser effect, and saved as a preset using the 'Save/Manage Curves' feature.
The plug-in also has a Help screen, which outlines the background and operation.
When installed, it appears as '78rpm EQ Curve' in the 'Generate' menu.
Comments or suggestions for improvement are welcome.
PO'L
78EQCurveGen.ny.zip
(3.01 KiB) Downloaded 424 times
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
Irish
Forum Crew
Re: 78rpm EQ Curve Generator
Permanent link to this post Posted by Gale Andrews » Sun Jul 11, 2010 6:43 pm
Hi Irish
Thanks for this. Just some off the cuff comments.
Path should start with C:/ or it will never be written on WIndows, so for example "C:/Program Files/Audacity/". "/Program Files/Audacity/" will do nothing except write to the current directory. Since this is a type 3 plug-in and C:/Program Files/Audacity/ is default for 1.2 where the plug-in won't work, perhaps best to just have the path as "C:/"?
I think it would be far more useful if a new write could insert into the xml file, not overwrite. I'd envisage people could enter a few curves at a time, then want to insert the curve once into their presets.
The correct name for our EQ effect is "Equalization" not "Equaliser" so that ought to be corrected in ;info line and Help.
Help will I expect overflow with OK button off-screen at 800x600 on Linux, and in any case lacks any help about whether user should normalise at 1 kHz. Add that to help and split Help file into two pages? Should 1 kHz normalise be on by default rather than off?
Similarly the confirmation of the curve with list of frequencies and gains will be off-screen on smaller screens. I assume a four-column list can't be written that you would read to the bottom in the first pair of columns, then up to the top on the second pair?
Hobbyhorse: I know it seems fashionable to run the value and unit together in GUIs ("0dB" instead of "0 dB) but I don't like it as it's hard to read and technical literature doesn't do this (nor does your result list) :D
Permanent link to this post Posted by whomper » Sun Jul 11, 2010 8:51 pm
Gale Andrews wrote:...
Path should start with C:/ or it will never be written on WIndows, so for example "C:/Program Files/Audacity/". "/Program Files/Audacity/" will do nothing except write to the current directory. ...
better to prompt for where to put it
not everybody keeps everything on c:
or has a floppy disk at a:
(which happened to my photos on disk back when when the kodak idiots set it up so you could only see the pix from the a: drive with no option to change it and no way to copy them without using their braindead reader that was hardwired to a:)
andor
suggest you navigate to the audacity location in use
in case folks have more than one version
whomper
Probationer
Permanent link to this post Posted by whomper » Sun Jul 11, 2010 8:59 pm
Irish wrote:... However the number of EQ curves which exist for 78's (each record label had its own EQ curve)
How it Works
All 78rpm EQ curves are defined by two parameters; a Bass Turnover Frequency and a 10kHz Rolloff value. ... I should point out that the only basis I have for this addition is common sense and a gut feeling (plus the fact that it is explicitly included as a component in the RIAA curve which replaced the multiplicity of EQ curves in the 1950's), so if anyone can point me to some factual information on this element, I would be grateful....
close enough for govt work
every label did its own thing for sure back on 78s
so what you have should be good enough
unless somebody with a 78 can track down the eq actually used for a particular record
i think that may be generally true , but suspect riaa did it that way as a convenient compromise not something that was absolute.
besides, if they dont like the result they can re-eq to suit their ears
whomper
Probationer
Permanent link to this post Posted by Gale Andrews » Sun Jul 11, 2010 9:37 pm
better to prompt for where to put it - not everybody keeps everything on c:...
andor suggest you navigate to the audacity location in use in case folks have more than one version
The point is that if the path says C:/, the file will at least be written to the path indicated in the result, and it gives people the correct syntax that they can append to. If the path does not exist, the file will be written to the current folder even though the result indicates it has been written to the specified path.
The suggestion I made for the same problem in Sample Printer was that the text for the control said "Unique, pre-existing output pathn(writes to current folder if empty/invalid)".
Permanent link to this post Posted by Irish » Sun Jul 11, 2010 11:40 pm
I just wrote a long reply to Gale's comments and hit the 'Preview' button, only to find that I had been logged out (by the forum software?) and my post had evaporated into thin air.
It's too late to start again now; I'll try again tomorrow.
PO'L
Irish
Forum Crew
Permanent link to this post Posted by Gale Andrews » Mon Jul 12, 2010 3:03 am
Irish wrote:I just wrote a long reply to Gale's comments and hit the 'Preview' button, only to find that I had been logged out (by the forum software?) and my post had evaporated into thin air.
Sorry about that. If this happens, hitting back button without logging back in should probably allow you to capture the text that you had, assuming a decent modern browser.
Permanent link to this post Posted by waxcylinder » Mon Jul 12, 2010 11:08 am
My workaround for this when writing a long post is to select the whole message from time to time and hit the Ctrl+C button to put it on my paste buffer (that is when I remember - I still get caught out form time to time :) ).
In fact sometimes I will write a long response in Word and then paste that into the reply pane! :roll:
waxcylinder
Permanent link to this post Posted by Irish » Mon Jul 26, 2010 1:50 pm
Just in case anyone was waiting for the updates to the plug-in (!), the reason nothing has happened is that, first my IP address was blocked by Spamhaus, and then I went on holidays - this is coming from an internet cafe in northern Italy.
I'll be back in late August.
PO'L
Irish
Forum Crew
Permanent link to this post Posted by Irish » Sun Aug 22, 2010 11:36 pm
Here is the updated version of the EQ curve generator.
It includes some new features, in addition to fixing the problems in the earlier version.
Gale Andrews wrote:Path should start with C:/
I've set the default to C:/, as suggested, though it seems like a "least worst" solution.
Gale Andrews wrote:I think it would be far more useful if a new write could insert into the xml file, not overwrite.
I don't know if that is possible. The Nyquist manual states that when a file is opened for output, its current contents are discarded. In any case, if you could append data as default, you would have to purge the xml file at intervals, to avoid having multiple copies of curves imported into Equaliser.
Gale Andrews wrote:Help will I expect overflow with OK button off-screen at 800x600 on Linux
I've re-formatted the Help screens, and the output is now in two columns (though a bit clunky, since there doesn't seem to be an easy way to output a floating-point number in fixed-format with anything other than six decimal places). I think it should now be OK on 800 x 600.
Normalising to 0 dB at 1 kHz is now on by default, and I have included a feature to generate the EQ curve combined with the inverse RIAA curve, for users whose turntable pre-amp can't be set to "flat".
PO'L
78EQCurveGen.zip
Version 2 of the EQ Curve Generator Plug-in
(4.74 KiB) Downloaded 344 times
Irish
Forum Crew
Next
Return to New Plug-Ins
Who is online
Users browsing this forum: No registered users and 0 guests
