where does the saved draft go? how do I retrieve it? did you receive the message I just typed and saved (but didnot click submit) about the meter toolbar?
Thank you.
Topic moved to the “Maintaining / Improving this Forum” section as it’s not really about Audacity.
Near the top right corner of the page you should see a link to “User Control Panel”. Drafts are saved in there.
When you look at a list of your saved drafts there are links to “Load” or “Edit” the draft. “Load” the draft will “post” it.
Just to add, since I was replying at the same time, it’s at “Manage drafts” under the “Overview” tab in the User Control Panel.
After you “Submit” your message it will still have to be approved before you can see it.
