Hi
I’m trying to delete sections that I don’t want. I load the MP3. Then choose a section, then cut. So far, so good. Then I try to do another section. I can select it, but it won’t delete, cut or copy. If I close the entire program, and bring it up again. I can then select and cut one more section. One section at a time is a little slow. There has got to be a way to selection and cut a section and repeat this several times without having to close the program each time.
Denise
