I have my mixer plugged into the “line in” and it’s really fuzzy and quiet… I wondered why, but then I found out that it was recording my windows sounds (Like msn windows popping up and such). How do I stop it from recording everything thats going with my computer and record from my mixer. I does record the audio coming from my mixer but it’s really quiet.
Do you have a forum-related question like requesting a change to the order of the forum windows or admiration of the color of the graphics?
If you have an Audacity Windows question, it should probably go up in the Windows portion under the version of Audacity you’re using.
That makes it a lot easier for us to find you and be helpful.
