Advanced voice isolation
Permanent link to this post Posted by Ryko89 » Sat Apr 16, 2011 3:25 am
been trying out a few guides and plug-ins and such to isolate the voice in this audio clip:
http://www.sendspace.com/file/g9gdm6
But for no use, the quality of the voice fails. But then again, this is only me failing. I'm not very good with this program, so I was hoping that any one of you could step up to the challenge and help me extract that voice and removing the background noises and music. I know this probably isn't the place for requests and whatnot, but I'm on a deadline with this so I was hoping to get lucky =)
-Ryko
Ryko89
Re: Advanced voice isolation
Permanent link to this post Posted by steve » Sat Apr 16, 2011 11:16 am
Voice isolation is notoriously difficult. It's like trying to extract a banana from a banana milk shake.
This sample has been produce by using the "Vocal Removal" effect in Audacity 1.3.13, then using the result as a noise profile in the Noise Removal effect, and applied to the original audio track. The Equalization effect has then been applied to remove low bass and high treble. Finally the track has been "Envelope" shaped to remove the unwanted parts. With more time and effort tweaking the effects you may achieve slightly better results (this was done quite quickly), but I'll be surprised if you get much better.
isolated-voice.flac
(71.86 KiB) Downloaded 650 times
Senior Forum Staff
Operating System: Linux Debian
Permanent link to this post Posted by Trebor » Sat Apr 16, 2011 3:07 pm
alternatively the spectral subtraction ("Kn0ck0ut") method ...
you'll never find em (before-after 'knockout').mp3
(274.5 KiB) Downloaded 707 times
which has replaced the unwanted music with horrible digital artifacts :(
Trebor
Permanent link to this post Posted by Ryko89 » Sat Apr 16, 2011 7:35 pm
thank you so much for the help. I think this will suffice for what I need. Thanks a lot. The bit of background music left in Steve's sample will be no problem.
Thanks both of you, hope you all have a nice weekend ^^
Ryko89
Permanent link to this post Posted by RamonFHerrera » Sun Jan 18, 2015 2:39 pm
steve wrote:Voice isolation is notoriously difficult. It's like trying to extract a banana from a banana milk shake.
[Ominous voice] Hey, Steve: This is your buddy, Ramon, from the future. Well, 4 years after your post, anyway. ;-)
Check this out:
http://patriot.net/~ramon/misc/About-this-Non-Negative-Business.pdf (the PDF contains audio clips)
Then, when you are ready to have your socks blown off, take a seat and watch this one:
http://web.engr.illinois.edu/~paris/demos/ai/user-guide.mp4
It seems like the banana has Houdini-like qualities and inclination...
-Ramon
RamonFHerrera
Permanent link to this post Posted by steve » Sun Jan 18, 2015 6:45 pm
Terrific Ramon. When are you going to program it for us?
Senior Forum Staff
Permanent link to this post Posted by RamonFHerrera » Mon Jan 19, 2015 1:25 pm
steve wrote:Terrific Ramon. When are you going to program it for us?
It would be more like steal it, from the Sphinx source code. We will have to, of course, adapt the stolen code for our specific needs..
Wait a minute !! I just realized something!!!
Now that I think about it, the Sphinx source code belongs to the US Taxpayer !!!
-Ramon
ps: Have you seen the thread "KMan, I am glad to report that your problem is solved..." ???
RamonFHerrera
Permanent link to this post Posted by steve » Mon Jan 19, 2015 1:45 pm
RamonFHerrera wrote:the Sphinx source code belongs to the US Taxpayer !!!
No it doesn't. It is open source software.
RamonFHerrera wrote:We will have to, of course, adapt the stolen code for our specific needs..
I look forward to seeing your progress with that.
RamonFHerrera wrote:ps: Have you seen the thread "KMan, I am glad to report that your problem is solved..." ???
Yes, why?
Senior Forum Staff
Return to Audio Processing
Who is online
Users browsing this forum: No registered users and 8 guests
