Hello
is anybody using this soundcard with audacity?
I purchased it specifically because i thought i could record 3 channels simultaneously but can’t see a way of doing this in Audacity.
I either have the option to record a single mono channel or a single STEREO track even though i can plug 3 things into it.
Any advice gratefully received !
If you look at the reviews of the device on Amazon there are several that comment on the fact that it is stereo output only. Looking at the controls it doesn’t look like you can even pan the microphone input.
Page 6 of the Audiogram 3 manual (emphasis mine):
https://uk.yamaha.com/en/products/contents/music_production/downloads/manuals/index.html?k=&c=music_production&l=en
Connect To Your Computer via a Single USB Cable (page 8)
The AUDIOGRAM interface connects to your computer via the supplied USB cable. > Stereo audio
data is transferred in both directions—from the interface to the computer, and vice-versa—via the
USB connection (44.1 kHz or 48 kHz sampling frequency).
