The usual method for recording sounds playing on the computer is to set the recording input to "Stereo Mix".
This method is specific to Windows, and sadly is often not available on modern machines (particularly with Vista and Win 7).
Other methods for Windows are described here: http://manual.audacityteam.org/man/Tuto ... on_Windows
A (new to me) method that I have recently tried with success is using a small program called "Sound Leech".
This program is a "free to try" evaluation versio. The evaluation version appears to be fully functional. Registration is on an honesty basis (if you use it you should pay for it to support the developers costs).
http://www.milosoftware.com/en/index.php
As an experiment I tried recording Skype with Sound Leech and it successfully recorded the "other" party. I was also able to record "my" side of the conversation using Audacity to record the input from my microphone, so ending up with two recordings - my side in Audacity and the other side from Sound Leech. The Sound Leech recording is 44.1 kHz stereo WAV, which can then be imported into Audacity and manually synchronised with the microphone recording.
