1.3.8 failed installation - code 14001- help please
Permanent link to this post Posted by robo_123 » Sat Jul 18, 2009 3:19 pm
Tried to install 1.3.8 on laptop running XP - error message
unable to execute , createprocess failed code 14001
application configuration incorrect
suggests try re installing - have done so - no success
any suggestions ? on how to get this great programme woking as never had an issue
with any version before - upto now using 1.3.7 no issues
thanks
robo_123
Re: 1.3.8 failed installation - code 14001- help please
Permanent link to this post Posted by waxcylinder » Sun Jul 19, 2009 9:24 am
There are some known problems with the 1.3.8 release - see this thread: http://forum.audacityteam.org/viewtopic.php?f=24&t=11513
Your issue may well be related to this.
waxcylinder
Permanent link to this post Posted by Gale Andrews » Sat Jul 25, 2009 1:39 am
waxcylinder wrote:There are some known problems with the 1.3.8 release - see this thread: http://forum.audacityteam.org/viewtopic.php?f=24&t=11513
It is the same issue that was causing 1.3.8 not to launch on some Windows XP machines.
You can get the fixed installer and zip files here:
http://audacity.googlecode.com/files/au ... -1.3.8.exe
http://audacity.googlecode.com/files/au ... -1.3.8.zip
Permanent link to this post Posted by bojanson » Sat Jun 05, 2010 3:18 pm
I reinstalled with that link and it seemed to work. Maybe its time for me to upgrade my good ol windows xp :)
bojanson
Permanent link to this post Posted by Gale Andrews » Sat Jun 05, 2010 5:51 pm
bojanson wrote:I reinstalled with that link and it seemed to work. Maybe its time for me to upgrade my good ol windows xp :)
Please note the current Beta is 1.3.12. It doesn't have the issue noted in this thread.
Return to Windows
Who is online
Users browsing this forum: No registered users and 2 guests
