Build Audacity with mod-script-pipe on Raspberry Pi [SOLVED]
Audio software developers forum.
Re: mod-script-pipe.so won't load
Permanent link to this post Posted by adaptiman » Wed Mar 21, 2018 11:58 pm
/tmp is writable by the non-privileged user.
While there, I saw that there were two files in there owned by root:
audacity_script_pipe.from.0
audacity_script_pipe.to.0
I changed the ownership of these files to the non-privileged user, but it didn't work.
adaptiman
Operating System: Linux Debian
Permanent link to this post Posted by steve » Thu Mar 22, 2018 12:16 am
adaptiman wrote:While there, I saw that there were two files in there owned by root:
They would be created when you ran Audacity (with mod-script-pipe) as root. (user id for root is 0)
These are not normal files, they are named fifo pipes.
When you launched Audacity as root, did you not see an error / warning:
Code: Select all
Audacity could not find a place to store temporary files.
Please enter an appropriate directory in the preferences dialog.
Permanent link to this post Posted by adaptiman » Thu Mar 22, 2018 4:08 am
steve wrote:When you launched Audacity as root, did you not see an error / warning:
Code: Select all
No, I didn't see this warning even though the files were not owned by root. After launching as roo, when I checked the owner in /tmp, it was changed BACK to root (I assume by the program).
adaptiman
Permanent link to this post Posted by steve » Thu Mar 22, 2018 8:25 am
Did you "make" mod-script-pipe as root?
Permanent link to this post Posted by adaptiman » Thu Mar 22, 2018 1:58 pm
steve wrote:Did you "make" mod-script-pipe as root?
No, but I did sudo make install to install.
adaptiman
Permanent link to this post Posted by steve » Thu Mar 22, 2018 2:36 pm
adaptiman wrote:No, but I did sudo make install to install.
Clear as mud :D
Is this what you did:
From the Audacity source root
Code: Select all
./configure <options>
make
from /lib-src/mod-script-pipe
Code: Select all
make
all of the above on the same day.
Then to install Audacity, from Audacity source root:
Code: Select all
sudo make install
then copy (as normal user), mod-script-pipe.so to:
Code: Select all
~/.audacity-files/modules/
Permanent link to this post Posted by adaptiman » Thu Mar 22, 2018 4:06 pm
From /home/pi, I have cloned the latest repos of wxWidgets and Audacity. Then:
Code: Select all
cp -r wxWidgets wxWidgets-dev
cd wxWidgets-dev
git reset --hard 721d62a //this is the tag for the latest wxWidgets 3.0.4 release
./configure --with-gtk
./make -j3 //the -j3 tag uses three cores (don't want to get too hot ;-))
cd ..
cp -r audacity audacity-dev
cd audacity-dev
git reset --hard 2fef7f3 //this is the tag for the latest Audacity 2.1.3 release
./configure <options> //including specifying WX_CONFIG=/home/pi/wxwidgets-dev/wx-config
cd ./lib-src/mod-script-pipe/
make -j3
cd ..
make -j3
sudo make install
cd ..
mkdir .audacity-files
cd .audacity-files
mkdir modules
cd modules
cp ../../audacity-dev/modules/mod-script-pip.so ./
After executing Audacity as the nonprivileged user, the modules dialog can't find mod-script-pipe.
adaptiman
Permanent link to this post Posted by steve » Thu Mar 22, 2018 7:47 pm
OK, so I've tried building and installing 2fef7f3, but with wxWidgets 3.0.2 and on a laptop rather than a Pi, and mod-script-pipe works fine for me.
I'm running out of ideas, short of scrubbing the system and starting again from scratch.
Permanent link to this post Posted by steve » Thu Mar 22, 2018 8:00 pm
Grasping at straws...
From ~/.audacity-files/
What's your output from
Code: Select all
ls -la
and then again from ~/.audacity-files/modules
Permanent link to this post Posted by steve » Thu Mar 22, 2018 8:03 pm
and is ~/.audacity-data/audacity.cfg writable?
PreviousNext
Return to General Audio Programming
Who is online
Users browsing this forum: No registered users and 2 guests
