Build Audacity with mod-script-pipe on Raspberry Pi [SOLVED]
Audio software developers forum.
Re: mod-script-pipe.so won't load
Permanent link to this post Posted by steve » Wed Mar 21, 2018 10:28 am
Launch Audacity from your normal log-in account, then look in "Help > Diagnostics > Show Log". Anything in there related to the module?
Permanent link to this post Posted by Ixnay » Wed Mar 21, 2018 2:37 pm
Hello,
I have a quite similar issue. I have mod-script-pipe recognized in Preferences > Modules, and enabled, but it doesn't seem to be loaded. The pipes are not created. Though it worked the first time after installation, it did not work anymore after the computer restarts.
Do you have an idea of what is going on ? :?:
Ixnay
Operating System: Linux Mint
Permanent link to this post Posted by steve » Wed Mar 21, 2018 3:05 pm
Ixnay wrote:The pipes are not created
Are you looking in "/tmp"?
On Linux, if mod-script-pipe is enabled (as can be seen in "Edit > Preferences > Modules", but only after restarting Audacity), then you should see two files in "/tmp":
Code: Select all
/tmp/audacity_script_pipe.from.1000
/tmp/audacity_script_pipe.to.1000
The number at the end may be different (that depends on the logged-in user ID).
Permanent link to this post Posted by Ixnay » Wed Mar 21, 2018 4:15 pm
Code: Select all
Yes, that is where I look for the pipes. I have this issue on two computers (Ubuntu & Linux Mint). No specific message related to mod-script-pipe in the logs. If I choose 'ask' for the module nothing shows up when Audacity starts.
Ixnay
Permanent link to this post Posted by steve » Wed Mar 21, 2018 4:20 pm
Ixnay, If you launch Audacity and then open the Preference page for modules, does it say that the module "mod-script-pipe" is "Enabled"?
Permanent link to this post Posted by Ixnay » Wed Mar 21, 2018 4:33 pm
Yes, it does. (if I choose "Ask", then if I start again I can read "Ask" in the preferences but actually it asks for nothing)
Ixnay
Permanent link to this post Posted by steve » Wed Mar 21, 2018 4:49 pm
Like this?
Permanent link to this post Posted by Ixnay » Wed Mar 21, 2018 5:25 pm
Oh I got the thing... It's a problem of PATH too, it does not find the module but as the first time I started audacity from the installation folder, he found it the first time and saved it in the preferences. It works again when I start audacity from the installation folder. But now I fall into the same issue as the author of the thread...
Ixnay
Permanent link to this post Posted by Ixnay » Wed Mar 21, 2018 5:39 pm
Ok I put the module in ~/.audacity-files/modules/ and now it seems to work ! (I didn't figure out why it does not work in the same folder as plugins) thnk you
Ixnay
Permanent link to this post Posted by steve » Wed Mar 21, 2018 6:24 pm
Ixnay wrote:I didn't figure out why it does not work in the same folder as plugins
"Modules" and "Plug-ins" are different. "Plug-ins" have to go in the plug-ins path, and "modules" have to go in the modules path.
If Audacity is properly installed at:
Code: Select all
/usr/local/share/audacity
then Audacity should be able to find files that are in:
Code: Select all
/usr/local/share/audacity/modules/<name-of-module>.so
However, I would recommend putting the module into:
Code: Select all
~/.audacity-files/modules/<name-of-module>.so
as this is a "per user" installation and is independent of the installation path of Audacity.
PreviousNext
Return to General Audio Programming
Who is online
Users browsing this forum: No registered users and 2 guests
