Build Audacity with mod-script-pipe on Raspberry Pi [SOLVED]
Audio software developers forum.
Permanent link to this post Posted by adaptiman » Mon Mar 19, 2018 7:05 pm
I've compiled Audacity 2.2.2 as well as mod-script-pipe.so. I've also run make install. For my installation, the audacity executable is located in /usr/local/bin/. I've tried all of the locations to copy mod-script-pipe.so to register it with no avail. When accessing the modules dialog, Audacity returns
Code: Select all
No modules were found
So far, I've tried these locations:
/usr/local/bin/modules/
/usr/local/share/audacity/modules/
~/audacity-build-directory/modules/
~/.audacity-files/modules/
~/.audacity-data/modules/
When I execute audacity as root (i.e., sudo audacity) the module is read, but I don't know which copy of the file is being read, nor how to fix the installation so I can run audacity as a non-priviledged user. Any tips on getting mod-script-pipe to load correctly?
adaptiman
Operating System: Linux Debian
Re: mod-script-pipe.so won't load
Permanent link to this post Posted by steve » Mon Mar 19, 2018 7:26 pm
It should work in:
Code: Select all
~/.audacity-files/modules/mod-script-pipe.so
Note that after enabling it in Preferences, Audacity must be restarted.
Permanent link to this post Posted by adaptiman » Mon Mar 19, 2018 7:46 pm
steve wrote:It should work in:
Code: Select all
That location doesn't work. The only path I can get it to register is:
/usr/local/share/audacity/modules/mod-script-pipe.so
and ONLY when executing Audacity as root via sudo audacity. I have successfully registered and loaded the module when executing as root. The non-privileged user can't see the file, probably because of a permissions problem.
adaptiman
Permanent link to this post Posted by steve » Mon Mar 19, 2018 8:53 pm
You should not need to run Audacity as root.
Code: Select all
should also work, but should not require running as root. Is your user account the owner of mod-script-pipe.so
I've got it mod-script-pipe in:
Code: Select all
and the permissions are:
Code: Select all
-rwxrwxr-x 1 <user> <user> 409320 Mar 19 13:35 mod-script-pipe.so
Permanent link to this post Posted by adaptiman » Mon Mar 19, 2018 9:04 pm
Code: Select all
$ ls -al ~/.audacity-files/modules/mod-script-pipe.so
-rwxrwxr-x 1 pi pi 40552 Mar 19 15:55 /home/pi/.audacity-files/modules/mod-script-pipe.so
Still doesn't work.
adaptiman
Permanent link to this post Posted by steve » Mon Mar 19, 2018 11:28 pm
and I presume that you are logged in as "pi"?
Permanent link to this post Posted by adaptiman » Mon Mar 19, 2018 11:40 pm
steve wrote:and I presume that you are logged in as "pi"?
Yes sir. Sorry for the trouble, and thanks for the help!!
adaptiman
Permanent link to this post Posted by steve » Tue Mar 20, 2018 9:33 am
I don't understand why it only works for you when running as root, so I've posted to the developer's mailing list to see if anyone there has any ideas.
Permanent link to this post Posted by adaptiman » Wed Mar 21, 2018 2:36 am
I've done some more checking and confirmed the following conditions:
1. The module only loads when audacity is run as root, and will load if the module is located in either:
/root/.audacity-files/modules/mod-script-pipe.so
or
2. The module will not run under the non-privileged user in any location that I have tried. I have confirmed permissions on files in all of the typical locations and am tending toward thinking it's probably not a permissions problem.
3. The location in the source where the module file paths are defined is in and about:
/src/AudacityApp.cpp (1275)
I can't see anything wrong with the code (then again, I'm not a C programmer).
At this point, I suspect that the problem is seeing/loading the module requires a process that requires elevated privileges, although I don't know what that would be. I'm going to do some checking along these lines, but there definitely seems to be a problem, either with the configuration of my Debian system (probably) or Audacity itself (possible).
adaptiman
Permanent link to this post Posted by steve » Wed Mar 21, 2018 10:25 am
What are the file permissions for your "/tmp" folder? (mod-script-pipe requires rw access to /tmp)
Next
Return to General Audio Programming
Who is online
