Operating Audacity from the command line (experimental)
Audio software developers forum.
Permanent link to this post Posted by steve » Tue Mar 13, 2018 9:35 pm
This is a short demo of controlling Audacity via the command line (in a terminal) using a Python script "pipeclient.py" (https://github.com/audacity/audacity/bl ... eclient.py)
This demo is running on Linux, but the script should also work on other platforms.
Currently it is necessary to build Audacity from source to enable scripting, though it is hoped that scripting will be available for general release fairly soon (no release date available yet).
Click on the image below to expand, or right click the image and select the appropriate option to view the full image (it's an animated GIF, which should be supported by most modern browsers).
Return to General Audio Programming
Who is online
