How to make your voice like this? (Presumably helmet-radio)
Audio software developers forum.
Re: How to make your voice like this? (Presumably helmet-rad
Permanent link to this post Posted by Trebor » Sun Nov 19, 2017 4:41 pm
steve wrote:I also notice that you have two controls; "constant hiss" and "constant crackle", but they are not constant because you multiply them by *track*. So when *track* is silent, then the "constant" hiss and crackle will be silent.
Again I'm nut sure what you want, but if you want the hiss and crackle to vary with the voice, then these controls should perhaps be renamed as just "hiss" and "crackle".
There were two different crackles: one only on voice, and another constant one which would add crackle to silence.
Similarly "constant hiss" adds hiss even when there is no voice ...
Trebor
Permanent link to this post Posted by Trebor » Mon Nov 20, 2017 2:33 am
Version 1.3 ...
HelmetRadio1-3.NY
(1.77 KiB) Downloaded 11 times
I had to revert to the old noise-generators. Your noise-code was more elegant but it wasn't producing the same radio-like hiss & crackle sounds. "clip2", (effectively normalizing to 0dB before clipping), also had to go : it was making the very clipped sounds deafeningly loud.
HelmetRadio 1.3 , like previous versions only produces (optional) constant hiss & crackle on the left channel, so OK for mono , not stereo . (Oddly the radio-crackle, which only occurs with speech, is on both channels).
Trebor wrote:Not just helmets: the plugin is also usable for simulating Lo-Fi loudspeakers: intercom, speaker-phone, cheapo-cassette.
Add enclosed telephone-booths to that list.
Trebor
Permanent link to this post Posted by Trebor » Mon Nov 20, 2017 7:09 am
HelmetRadio1-3 does a pretty good analogue telephone ...
'Analogue-Telephone' settings.png (12.2 KiB) Viewed 1151 times
before-after, DonaldT on analogue telephone.flac
(642.67 KiB) Downloaded 14 times
Trebor
Previous
Return to General Audio Programming
Who is online
Users browsing this forum: No registered users and 2 guests
