Making it rain (in audio)
Audio software developers forum.
Permanent link to this post Posted by waverlye » Thu Aug 03, 2017 9:31 pm
Would anyone have some direction on how to make it rain (in audio). I have a goal to create some reasonably (or better) realistic rain sounds. The easiest thing to do would be to utilize a sound effect and put it on a loop but I've been wondering can this be generated programmatically and still sound pretty realistic.
Thank you,
W.
waverlye
Re: Making it rain (in audio)
Permanent link to this post Posted by kozikowski » Thu Aug 03, 2017 10:16 pm
Particularly if its covered up with dialog and other theatrical stuff, fading in Generate > Noise: Pink should do it. If someone walks from inside to outside, switch from pink to white noise.
These are a cousin to microphone internal noises which I frequently refer to as "Spring rain in the trees."
It probably wouldn't work by itself, but if Marsha turns to John and says, "Oh look. It's starting to rain."
rainclip.mp3
(17.73 KiB) Downloaded 28 times
Permanent link to this post Posted by Trebor » Thu Aug 03, 2017 10:17 pm
waverlye wrote:Would anyone have some direction on how to make it rain (in audio) ...
Heavy-rain / Waterfalls make brown-noise ... https://en.wikipedia.org/wiki/Brownian_ ... xplanation
Trebor
Permanent link to this post Posted by kozikowski » Fri Aug 04, 2017 4:33 am
That's special California® rain.
Permanent link to this post Posted by waverlye » Mon Aug 07, 2017 3:55 pm
Yes, I can hear the rain now :)
Brownian noise. That is good info to follow up on.
I'm getting closer.
Thank you both very much,
W.
waverlye
Permanent link to this post Posted by Trebor » Mon Aug 07, 2017 5:48 pm
waverlye wrote:I'm getting closer.
There's a Nyquist plugin for Audacity called Random Amplitude modulation to vary the volume.
I think you'll need a similarly random highpass filter to make it sound realistic.
Trebor
Permanent link to this post Posted by waverlye » Tue Aug 08, 2017 5:26 pm
Trebor wrote:There's a Nyquist plugin for Audacity called Random Amplitude modulation to vary the volume.
I can imagine how this would be beneficial. I will definitely look into this.
Thank you,
W.
waverlye
Return to General Audio Programming
Who is online
