adding audacity audio files to video
Audio software developers forum.
Permanent link to this post Posted by mickthefish » Wed Aug 03, 2016 10:33 am
can audacity be used to insert(dub) its music files into video files.or is there any audacity software that can do this. mickthefish.
mickthefish
Operating System: Windows XP
Re: adding audacity audio files to video
Permanent link to this post Posted by Trebor » Wed Aug 03, 2016 11:02 am
mickthefish wrote:can audacity be used to insert(dub) its music files into video files.or is there any audacity software that can do this. mickthefish.
You can extract (aka rip*) the audio from the video file, and edit the audio in Audacity,
but you need video-editor software to replace the video soundtrack ...
https://en.wikipedia.org/wiki/List_of_video_editing_software#Free_and_open-source
Here's a tutorial using the free Avidemux video-editor ... https://www.youtube.com/watch?v=xS1zl_SMRbk
[* if you have FFmpeg installed in Audacity ].
Trebor
Permanent link to this post Posted by mickthefish » Thu Aug 04, 2016 1:05 pm
thanks trebor your reply has been very helpful.i will use your suggested net sites to see if theres anything i can use & get back to you---regards,mick. :D
mickthefish
Permanent link to this post Posted by Trebor » Thu Aug 04, 2016 4:52 pm
mickthefish wrote:.. see if theres anything i can use ...
If you're on Windows then MovieMaker is a (very) basic video-editor from Microsoft & free ...
https://en.wikipedia.org/wiki/Windows_Movie_Maker
It may already be installed on your Windows OS.
Trebor
Permanent link to this post Posted by mickthefish » Mon Aug 15, 2016 12:47 pm
it turns out that inserting music files into video files is much more difficult than i thought,ill keep trying though.there is software out there somewhere!!.mickthefish. :(
mickthefish
Permanent link to this post Posted by Trebor » Mon Aug 15, 2016 3:30 pm
mickthefish wrote:it turns out that inserting music files into video files is much more difficult than i thought,ill keep trying though.there is software out there somewhere!!.mickthefish. :(
Apparently there are "online" video* editors : with them you don't install software on your machine.
You upload the video, process it "in the cloud", then download the resulting video ...
http://filmora.wondershare.com/video-editor/free-online-video-editor.html
Trebor
Return to General Audio Programming
Who is online
