New to the forum and Audacity. I am using it to analyse bat echolocation calls. How do I change the frequency scale to go up to 145 kHz?
I did try the mag-glass that appears when but it only moves the scale up or down, not increases it. If I right click the mag-glss it only allows me to go from 0 to 22 kHz. If I left click it reduces the frequency scale down to 13-22, then 15 -19, then 16-18.3 etc. The largest range I can get is 0 to 22. Clicks after this do not go any further.
Also I have changed this in preferences under Tracks and Spectrograms in Min and Max frequencies. I hit apply nothing happens. I hit ok and nothing happens. It just stays at 0 to 22kHz.
I would really appreciate any help. Thank you.
