Linux distribution: Ubuntu 14.04 LTS
Audacity source being compiled: Version 2.1.1, made changed to ControlToolBar.ccp and .h
I attachd the Xorg log - nothing therethat I have clue about to be frank.
backtrace (printout in the terminal, not sure that’s what you mean):
(process:4065): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::sm-connect after class was initialised
(process:4065): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::show-crash-dialog after class was initialised
(process:4065): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::display after class was initialised
(process:4065): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::default-icon after class was initialised
(Audacity:4065): Gtk-WARNING **: gtk_disable_setlocale() must be called before gtk_init()
(Audacity:4065): IBUS-WARNING **: The owner of /home/alon/.config/ibus/bus is not root!
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
bt_audio_service_open: connect() failed: Connection refused (111)
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1736
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1904
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2171
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2840
ALSA lib pcm_dsnoop.c:618:(snd_pcm_dsnoop_open) unable to open slave
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4611
16:17:14: Debug: Unknown accel modifier: 'left'
16:17:14: Debug: Unknown accel modifier: 'click/left'
16:17:14: Debug: Unrecognized accel key 'drag', accel string ignored.
16:17:14: Debug: Unrecognized accel key 'click', accel string ignored.
16:17:14: Debug: Unknown accel modifier: 'right'
(Audacity:4065): Gtk-CRITICAL **: IA__gtk_text_attributes_ref: assertion 'values != NULL' failed
what do you mean by:
exactly what source you are recording from
Xorg.0.log (42.5 KB)
