Mixing of N tracks automatically
Audio software developers forum.
Permanent link to this post Posted by Axelito77 » Sun Jul 26, 2015 10:43 am
Hi there,
Would it be possible to automate the mixing of N tracks via Audacity?
Let me explain the process:
Input: I have a folder with N audio tracks (say 16 wav stems), some mono, some stereo, all starting at the same time.
Output: the resulting stereo mix file (wav)
Can this be done programmatically, without human intervention?
I can't wait :-)
Axel
Axelito77
Re: Mixing of N tracks automatically
Permanent link to this post Posted by kozikowski » Sun Jul 26, 2015 1:40 pm
Permanent link to this post Posted by steve » Sun Jul 26, 2015 3:07 pm
Axelito77 wrote:Can this be done programmatically, without human intervention?
Computers don't do anything without human intervention. You have to turn it on, launch programs (or create a script to launch the program(s) on boot), .... The question is "how much human intervention".
How is your computer going to know which files you want to mix? You can select them using "File > Import > Audio" or you can create a LOF file to tell Audacity which files, or you could create an AutoKeys script, or ....
How is your computer going to know how loud the mix should be?
How is your computer going to know the relative levels of each stem?
How is your computer going to know where to put each of the stems (or do they all start at time=0?
In short, yes you can automate things, but what exactly do you want to automate, and how much do you want to program?
Permanent link to this post Posted by Axelito77 » Sun Jul 26, 2015 5:19 pm
Agreed.
Well, in the end, I would like to be done on a server...
So no human intervention, except for the programming, testing and deploying :-)
Initially, I thought of creating the .aup file and then having audacity open it and recording the mix.
Maybe it would be easier to script the "File > Import > Audio" ???
I would mix at unity, ie 0dB.
The stems are already at the right level.
They all start at time=0
Thanks for your help.
Axel
Axelito77
Permanent link to this post Posted by kozikowski » Sun Jul 26, 2015 8:06 pm
What is the show or production? We've been led down the garden path before by someone dancing around describing the product or service. After many posts it turns out to be difficult or impossible, or, something already accomplished by an existing tool.
It's awkward working in a vacuum. It makes my ears hurt.
Permanent link to this post Posted by steve » Sun Jul 26, 2015 8:49 pm
Axelito77 wrote:Well, in the end, I would like to be done on a server...
If you mean an on-line web server, there are many reasons why Audacity is not a good tool for the job.
If you don't want to write a program from scratch, then SoX may be a better option: http://sox.sourceforge.net/
If you're dealing with PCM audio, then it may be easier to program the entire thing from scratch. "Mixing" two or more PCM files is simply a matter of summing the sample values.
Permanent link to this post Posted by Axelito77 » Fri Jul 31, 2015 4:23 pm
Thanks Steve !!!
You are correct about Sox.
This is the tool I am looking for.
Wow... It is so powerful.
Thanks again :-)
Axelito77
Return to General Audio Programming
Who is online
