Wish-list on Compressed saving
Anything you think is missing, or needs enhancement, goes here.
Permanent link to this post Posted by TommyN » Tue Nov 21, 2017 10:23 am
Hello,
I usually use the Compressed saving option; unfortunately, I just noticed that all my divisions within tracks disappear!!! They are very important for my music, and I guess they use very low memory to be stored: is it possible to preserve them, in the future version of the wonderful Audacity? :?:
Thank you!
TommyN
Re: Wish-list on Compressed saving
Permanent link to this post Posted by steve » Tue Nov 21, 2017 10:41 am
The way that "Save a compressed copy" works, is that each track is rendered (effectively the same as exporting) as OGG files, and these OGG files then replace the normal audio data. As when exporting a track, the track data forms a single audio file.
One thing that you could do, is to label each of the audio clips before saving the compressed copy. Then when you reopen the project, you can split the track at the label positions (http://manual.audacityteam.org/man/edit ... html#split)
Permanent link to this post Posted by TommyN » Wed Nov 22, 2017 11:42 am
steve wrote:The way that "Save a compressed copy" works, is that each track is rendered (effectively the same as exporting) as OGG files, and these OGG files then replace the normal audio data. As when exporting a track, the track data forms a single audio file.
So, if I understand right, my wish is not doable technically. Thanks, Steve!
TommyN
Permanent link to this post Posted by steve » Wed Nov 22, 2017 1:29 pm
TommyN wrote:So, if I understand right, my wish is not doable technically.
Nothing is impossible, but it would require a substantial change to how compressed saving works. Rendering tracks is currently an all or nothing affair for tracks - either mix and render the entire track, or nothing - Audacity can't render just part of a track, so that facility would need to be written before work could begin on rendering single clips when saving.
In my opinion, it would be 'possible', but would need to be part of a bigger reworking of how we save projects (a lossless compressed copy of the project might be another nice feature).
There are a number of related feature requests on the wiki here: http://wiki.audacityteam.org/wiki/Featu ... Management
If you'd like to "vote" for any of these, just say which ones and I'll be happy to add your vote(s).
If you think that none of these adequately covers your request, perhaps you could suggest some wording for the wiki.
Permanent link to this post Posted by TommyN » Fri Nov 24, 2017 9:17 am
steve wrote:
TommyN wrote:If you think that none of these adequately covers your request, perhaps you could suggest some wording for the wiki.
I checked and did not find. I would suggest:
• Save project's compressed copy
1) Give the option to compress a project loss-lessly
2) Give the possibility to save the divisions present inside each track (instead of merging them all during the compression process): indeed, track divisions are essential -e.g. for music composing- and -especially if you have many- labeling them all and restoring them later would be very time consuming!
Many thanks!
TommyN
Permanent link to this post Posted by TommyN » Fri Nov 24, 2017 9:21 am
steve wrote:There are a number of related feature requests on the wiki here: http://wiki.audacityteam.org/wiki/Featu ... Management
PS I just saw, in another section (Import/Export), one point I would like to vote: the OFR!
TommyN
Permanent link to this post Posted by steve » Fri Nov 24, 2017 10:27 am
TommyN wrote:PS I just saw, in another section (Import/Export), one point I would like to vote: the OFR!
I've added your vote.
It would probably not be possible to build support for OptimFrog directly into Audacity because the OptimFrog license is not compatible with Audacity's GPL v2 open source software license:
http://losslessaudio.org/License.php
https://www.gnu.org/licenses/old-licens ... .0.en.html
If there is a command line encoder available for OptimFrog, then it should be possible to export as OFR using Audacity's "external program" export option:
"File menu > Save Other > Export Audio", then select "(external program)" from the Save as type dropdown menu.
Permanent link to this post Posted by steve » Fri Nov 24, 2017 10:40 am
TommyN wrote:I checked and did not find. I would suggest:
I've added a shorter version of those items and added your votes.
I'll also move this topic to the "Adding Features" section of the forum in case anyone else wants to vote or comment.
Permanent link to this post Posted by EricMC » Tue Feb 20, 2018 11:54 pm
I would like to upvote the option of a lossless compression, please.
EricMC
Permanent link to this post Posted by steve » Wed Feb 21, 2018 12:29 am
EricMC wrote:I would like to upvote the option of a lossless compression, please.
Vote added.
Return to Adding Features to Audacity
Who is online
Users browsing this forum: Google [Bot] and 1 guest
