GUI plugins, custom format plugins
Anything you think is missing, or needs enhancement, goes here.
Permanent link to this post Posted by Ondrej » Tue Oct 10, 2017 10:36 pm
Hi,
I work in speech research and I use audacity on a daily basis, however, there are lots of tiny things that would make my (and other researchers, I assume) life sooo much easier. I would be willing to write plugin for these things and share them, but it seems like plugins are only available for the audio signal processing. Here's a list of features that I'd appreciate so much, so perhaps someone might help with directing me to an appropriate documentation:
* custom label format --- I use labels, but they are in a slightly different format --- is there a way of writing a plugin that does a simple time conversion before loading the label file?
* importing raw audio and labels from command line --- I run audacity in linux and very often I would like to open raw files and/or labels from a command line. Is there a way to do it?
* pre-selecting different parameters for raw audio import (right now, the pre-filled value for sampling frequency of a raw file is 44100Hz, but I mostly work with 8kHz files, so it's very anoying to change the field each time I'm loading a file)
So most of the things are GUI-related.
Thank you
Ondrej
Operating System: GNU/Linux other
Re: GUI plugins, custom format plugins
Permanent link to this post Posted by steve » Tue Oct 10, 2017 11:15 pm
It looks to me like you need a customised version of Audacity rather than plug-ins. Do you program in C++?
Permanent link to this post Posted by Ondrej » Tue Oct 10, 2017 11:20 pm
I do a bit, yes.
Ondrej
Permanent link to this post Posted by steve » Tue Oct 10, 2017 11:31 pm
The first step in building a custom version, is to build a standard unmodified version first. Once you've got that working you can then begin studying and modifying the code.
Basic build instructions for Linux are here: https://github.com/audacity/audacity/bl ... er/INSTALL
Permanent link to this post Posted by Ondrej » Wed Oct 11, 2017 12:35 am
Thanks, will give it a try. Much appreciated
Ondrej
Return to Adding Features to Audacity
Who is online
Users browsing this forum: No registered users and 2 guests
