Timecode entry instead of seconds.
Anything you think is missing, or needs enhancement, goes here.
Permanent link to this post Posted by Galane » Fri Oct 06, 2017 7:31 am
Would be so much easier to enter time adjustments in timecode format instead of having to convert to seconds. If you need to change the runtime of a file from 1:38:06 to 1:57:40 it would be nice to be able to simply enter 1:57:40 instead of 7060 seconds.
Would also be nice if when stretching to 7060 seconds the output wouldn't come out 6 seconds too long at 1:57:46
Galane
Re: Timecode entry instead of seconds.
Permanent link to this post Posted by steve » Fri Oct 06, 2017 8:22 am
I presume that you are referring to this post: https://forum.audacityteam.org/viewtopi ... 09#p335009
As I wrote there, the correct tool for the job is most probably the "Change Speed" effect (http://manual.audacityteam.org/man/change_speed.html) and that does have the ability to to simply enter 1:57:40, and the resulting length is very accurate.
Return to Adding Features to Audacity
Who is online
Users browsing this forum: No registered users and 2 guests
