Audacity 2.2.0 alpha April 30th - skins
Anything you think is missing, or needs enhancement, goes here.
Re: Audacity 2.2.0 alpha April 30th - skins
Permanent link to this post Posted by Gale Andrews » Fri May 05, 2017 11:56 am
steve wrote:Shortcuts for the development (alpha) version are subject to change: http://alphamanual.audacityteam.org/man ... _Reference
Yes, and I think that Keyboard Shortcut Reference page is going to be replaced with http://alphamanual.audacityteam.org/man/Commands. So I would look at that Commands page for using 2.2.0-alpha.
Permanent link to this post Posted by Tapehead » Sat May 06, 2017 9:33 pm
Thanks Gale, Steve, got it now with the underlinings, I was looking in the menu themselves for them. I must have tried every key with ALT except C :D
Gale Andrews wrote:I think an answer could be to allow any type of preset to have a shortcut bound to it, and possibly (for GUI effects) add those shortcuts as a row of buttons at the top of the effect.
Some vsts have 50+ presets.
Maybe I use Audacity effects in a different way to the majority?
I work on a lot of experimental stuff and click back and forth between presets in multiple vsts a until something takes my fancy, then tweak it from there.
Tapehead
Permanent link to this post Posted by Gale Andrews » Sun May 07, 2017 1:17 pm
I think over time most users would find favourite presets that they are more likely to choose. If we had the suggested feature you could add presets for those.
Previous
Return to Adding Features to Audacity
Who is online
Users browsing this forum: No registered users and 2 guests
