Add a soft knee to compressor-effect
Anything you think is missing, or needs enhancement, goes here.
Permanent link to this post Posted by cazorla » Tue Feb 28, 2017 1:23 am
similar to ffmpeg's compressor - a smoother transition/thershold between normal and compressed
https://ishenspamangoma.wordpress.com/2016/03/08/ishens-tutorials-dynamic-range-compression/
cazorla
Re: Add a soft knee to compressor-effect
Permanent link to this post Posted by kozikowski » Tue Feb 28, 2017 2:09 am
Effect > Limiter in Audacity 2.1.2 has four different actions and one of them is Soft Knee. It works as a dynamic effect unlike Leveler which just smashes peaks.
I've been using it for AudioBook mastering with SetRMS and possible noise reduction. SetRMS is a custom tool that forces loudness. Then follow up with Soft Limiter to define peaks.
Somewhere in there may do what you want. Unzip this and copy the text into Effect > Nyquist.
http://www.kozco.com/tech/audacity/Docu ... MS.txt.zip
Return to Adding Features to Audacity
Who is online
Users browsing this forum: No registered users and 4 guests
