It would be a very handy feature to be able to automatically split incoming audio into separate tracks, either by silence detection, or more simply, just a timer.
Thanks.
Thanks.
You can use “Silence Finder” or “Regular Interval Labels” from the Analyze menu
http://www.audacityteam.org/wiki/index.php?title=Splitting_recordings_into_separate_tracks
That looks like it may do the trick. Thanks!
Hi there,I cannot seem to enable the silence finder plug-in,despite it being in the Nyquist and Plug-in folder.
How do I activate it ?
Thanks for any help,Howard
As with all effects and many other operations, you must have some audio selected that the effect is going to operate on. To select a complete track, click on the box at the left side of the track.
Hey!
**I solved IT!
Yahoooo!
Rad this post: https://forum.audacityteam.org/t/minimum-length-mod-for-silence-marker-and-sound-finder/11208/6
For using “Export Multiple” your modification will create too many tracks - (see response on Minimum length mod for Silence Marker and Sound Finder - #6 by triola )
