MSVS2013 Windows 10 compiling Audacity w/ ASIO prefs.h issue
Building and customizing Audacity from the source code.
Permanent link to this post Posted by psound74 » Fri Mar 30, 2018 12:25 am
Long time Audacity User, first time compiler...
The Good:
got Microsoft Visual Studio Community 2013
wxWidgets 3.0.2 - compiled & system variable set
help project - built (w/ python copying of "man" info from website)
ASIO SDK downloaded & system variable set
downloaded latest src of Audacity from Git - ok
The Bad:
prefs.h error (audacity project is the only one of the 25 that won't build)
Error 532 error C2440: 'default argument' : cannot convert from 'initializer-list' to 'const wxString &' c:\audacity-master\src\Prefs.h 96 1 Audacity
As near as i can tell looking online, it looks like i'd have to declare a "constructor" for this part of the prefs.h code, but i haven't the foggiest clue how to do this:
public:
EncodedEnumSetting( //this is line 96
const wxString &key,
const IdentInterfaceSymbol symbols[], size_t nSymbols,
size_t defaultSymbol,
const int intValues[] = nullptr, // must have same size as symbols
const wxString &oldKey = {}
: EnumSetting{ key, symbols, nSymbols, defaultSymbol }
, mIntValues{ intValues }
, mOldKey{ oldKey }
wxASSERT( mIntValues );
Help?
Thanks,
psound74
psound74
Re: MSVS2013 Windows 10 compiling Audacity w/ ASIO prefs.h i
Permanent link to this post Posted by steve » Fri Mar 30, 2018 11:14 am
psound74 wrote:wxWidgets 3.0.2 - compiled & system variable set
Have you tried building any of the wxWidget sample projects?
(It's not very up to date, but there's a guide here: https://wiki.wxwidgets.org/Microsoft_Vi ... B%2B_Guide)
Permanent link to this post Posted by psound74 » Sat Mar 31, 2018 1:27 am
Steve,
Yes, i was able to compile the wxWidgets 3.0.2 projects according to the instructions.
24 of the 25 projects in the Audacity solution had successful “build” as well...
psound74
Permanent link to this post Posted by roadsterUK » Sun Apr 01, 2018 7:50 pm
I see you have used Audacity master as your source code. This is in a version 2.3 Alpha development state and the contents of Prefs.h is significantly changed compared to the stable release version. Having just built 2.2.2 exactly as described by yourself I strongly suggest that you use 2.2.2 not master. You may encounter the run-time ASIO issue I have described in the adjacent post but you shouldn't have any trouble with compiling and linking. It is also possible to use wxWidgets 3.1.1 with a couple of small changes in memoryX.h and in the linker config for the mod-script-pipe project configuration.
roadsterUK
Permanent link to this post Posted by psound74 » Thu Apr 05, 2018 2:55 am
Thanks a lot roadsterUK!
Using 2.2.2 seemed to work...the only mysteries now are a 100ms delay/offset (regardless of ASIO buffer settings) when overdubbing subsequent tracks and the fact that the help menu seems to think i don't have the help file local to my drive (even though i compiled the Help project separately as directed)...
psound74
psound74
Permanent link to this post Posted by steve » Thu Apr 05, 2018 12:03 pm
psound74 wrote:the only mysteries now are a 100ms delay/offset (regardless of ASIO buffer settings)
You need to set up "latency correction" for the system: http://manual.audacityteam.org/man/latency_test.html
psound74 wrote:the help menu seems to think i don't have the help file local to my drive (even though i compiled the Help project separately as directed)...
I'd guess that you need to move the manual to the correct location. See: http://manual.audacityteam.org/man/unzi ... anual.html
Return to Compiling Audacity
Who is online
