MSSE Flag on ARM?
Building and customizing Audacity from the source code.
Re: MSSE Flag on ARM?
Permanent link to this post Posted by adaptiman » Mon Mar 19, 2018 2:32 am
steve wrote:
adaptiman wrote:and 3.1.2 for Audacity
There isn't a 3.1.2 version of Audacity.
Sorry - 2.1.3 of Audacity. I've edited my previous response to note the compilation error I get with mod-script-pipe. Any suggestions for specifying the wx paths?
adaptiman
Operating System: Linux Debian
Permanent link to this post Posted by steve » Mon Mar 19, 2018 2:42 am
adaptiman wrote:Any suggestions for specifying the wx paths
Once you've built wxWidgets, you can tell Audacity where to find it with a configure option like:
Code: Select all
./configure WX_CONFIG=/home/user/dev/wxbuild/wx-config
Permanent link to this post Posted by adaptiman » Mon Mar 19, 2018 3:00 am
Sorry for the noob question. How do I configure the mod-script-pipe object? I'm in the mod-script-pipe directory, but configure doesn't work. The make fails.
adaptiman
Permanent link to this post Posted by steve » Mon Mar 19, 2018 3:06 am
Run ./configure (+ options) in the root directory of the Audacity source, then cd to the mod-script-file directory and run "make" (to build mod-script-pipe), then cd back to the root of the Audacity source and run "make" again (to build Audacity).
If .configure completes without error, but building mod-script-file fails, then you may need to run
Code: Select all
make clean
in the mod-script-file directory,
and
Code: Select all
make distclean
then go through the configure and make steps again.
Permanent link to this post Posted by adaptiman » Sun Mar 25, 2018 2:30 am
steve wrote:When you get it working (being optimistic ;)), take a look at pipeclient.py
https://github.com/audacity/audacity/bl ... eclient.py). It should work with Python 2.7 or later (Python 3 recommended) and can be imported as a module to make writing and reading to the pipe easier. Note also that the temp directory where the pipe is created is hard coded to "/tmp" (rather than using TMPDIR environmental variable).
I got pipeclient.py to run. Is there any documentation about the commands that can be used?
adaptiman
Permanent link to this post Posted by steve » Sun Mar 25, 2018 1:38 pm
adaptiman wrote:I got pipeclient.py to run. Is there any documentation about the commands that can be used?
There is, but scripting is currently under heavy development, so the commands are changing radically in new versions of Audacity.
Note that scripting is still classed as "experimental", so it is subject to change without notice.
The information in the 2.2.2 manual (https://manual.audacityteam.org/man/scripting.html) should be mostly correct for recent releases, but Audacity 2.3.0 (the next release) has a lot of changes.
Previous
Return to Compiling Audacity
Who is online
