Uninstall Audacity and all its dependencies
Building and customizing Audacity from the source code.
Permanent link to this post Posted by vince66 » Sun Jul 02, 2017 6:48 pm
Hello everybody,
I have successfully installed Audacity from the source code. To do this i cloned the source from the github repository.
My question now is:
in which way i can uninstall it and all its dependencies (included in the git package) ?
Thanks in advance.
Vincenzo.
vince66
Re: Uninstall Audacity and all its dependencies
Permanent link to this post Posted by steve » Mon Jul 03, 2017 7:35 am
Presumably to install Audacity you ran
Code: Select all
sudo make install
To uninstall, run
Code: Select all
sudo make uninstall
from the same location.
After uninstalling, you can remove packages that were automatically installed to satisfy dependencies for other packages and are now no longer needed, in the normal way with:
Code: Select all
sudo apt autoremove
CAUTION: Always look to see what will be removed before confirming removal.
To remove the Audacity source code, just delete it.
If you installed wxGtk and no longer need it, you can uninstall it with your package manager. Similarly, Git may be uninstalled with your package manager.
Return to Compiling Audacity
Who is online
Users browsing this forum: No registered users and 2 guests
