Compiling 2.1.3-Problem with Help Folder
Building and customizing Audacity from the source code.
Permanent link to this post Posted by cmjone » Tue Jun 27, 2017 3:15 am
Hello:
I used Widgets 3.0.2 and VS 2013, the community edition to compile 2.1.2 successfully for ASIO without any failed projects. However, the local manual would not work. But I live with it. Now. I used the same procedure to compile 2.1.3. Every thing went fine except one failed project related to the Help manual. Either the Help folder was not able to be created or a copy of the manual could not be downloaded. The error message is as follows.
Error 230 error MSB3073: The command "set SRC="D:\Audacity\win\\..\help\manual"
set DEST="D:\Audacity\win\Release\help\manual"
cd ..\..\..\scripts\mw2html_audacity
if EXIST %SRC% goto built
wiki2htm.bat
:built
xcopy /I /E /C /Y /Q %SRC% %DEST%
:VCEnd" exited with code 2. C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.CppCommon.targets 122 5 help
Could anyone shed some light on this issue? Is there a bug in the code?
Thanks.
cmjone
Re: Compiling 2.1.3-Problem with Help Folder
Permanent link to this post Posted by Gale Andrews » Tue Jun 27, 2017 11:31 am
The Manual dump script often hangs except on Linux. Sometimes it will run better standalone after shutting down Visual Studio.
Don't forget that the Python library is required to build help, obtainable from http://www.python.org/download/. Add the location of the top-level directory where you installed Python to your Path environment variable. The Python installer might do this for you.
Permanent link to this post Posted by cmjone » Tue Jun 27, 2017 3:47 pm
I have put Python in the computer before compiling. I do not think Python is the problem.
cmjone
Permanent link to this post Posted by cmjone » Sat Jul 01, 2017 4:41 pm
Does it matter which version of Python?
Thanks.
cmjone
Permanent link to this post Posted by Gale Andrews » Sun Jul 02, 2017 1:25 pm
cmjone wrote:Does it matter which version of Python?
Not that I am aware, but 2.x.x is more compatible.
Return to Compiling Audacity
Who is online
Users browsing this forum: Bing [Bot] and 3 guests
