Building a Help project
Building and customizing Audacity from the source code.
Permanent link to this post Posted by cmjone » Sun Dec 25, 2016 1:22 am
I wonder if anyone can give me some instruction as to how to build a locally installed Help for Audacity. I have the Python in my computer now. How do you use Visual Studio to achieve the goal. I could not find anything
cmjone
Re: Building a Help project
Permanent link to this post Posted by Gale Andrews » Sun Dec 25, 2016 2:26 pm
cmjone wrote:I wonder if anyone can give me some instruction as to how to build a locally installed Help for Audacity. I have the Python in my computer now. How do you use Visual Studio to achieve the goal. I could not find anything
See "MSVC++ STEP 5: Consider and Configure Optional Features" in https://github.com/audacity/audacity/blob/master/win/compile.txt. The "help" folder should then appear in your build folder. You must be connected to the internet to build the help project.
If you built 2.1.2 release, you can instead download the Audacity Manual from http://manual.audacityteam.org/man/unzipping_the_manual.html.
Permanent link to this post Posted by cmjone » Sun Dec 25, 2016 10:56 pm
With the information Gale gave me, I finally got Audacity compiled for ASIO. I pretty much followed the instruction in Audacity/win/compile.txt. Thank you Gale. The instructions in this document are definitely very sketchy and even wrong.
This piece of document was written for the Audacity experts and not for the average Joe. Even if you are an expert in other forms of programming, you may still have problems in understanding it. I printed out the instructions and wrote a lot of notes on it. Now I become an expert to compile Audacity for use with ASIO. Just joking.
cmjone
Permanent link to this post Posted by steve » Mon Dec 26, 2016 11:14 am
cmjone wrote:This piece of document was written for the Audacity experts and not for the average Joe. Even if you are an expert in other forms of programming, you may still have problems in understanding it. I printed out the instructions and wrote a lot of notes on it. Now I become an expert to compile Audacity for use with ASIO. Just joking.
As with other programs, "the average Joe" would just download the Audacity executable and use it. Compiling a modified version of application from the source code is not what a average Joe typically does. ;-)
Joking aside, please tell us if you can make the instructions easier to follow, and do let us know about any error so that they can be fixed. Audacity is developed, documented, translated and supported by volunteers. If you can help, you are welcome to do so. (http://www.audacityteam.org/community/)
Permanent link to this post Posted by cmjone » Mon Dec 26, 2016 2:59 pm
I will do that. Just give me some time. I do not know when it will be though.
cmjone
Permanent link to this post Posted by Gale Andrews » Mon Dec 26, 2016 3:09 pm
There is no need to mention the problem with incorrect information about copying folders into Widgets. We'll correct that, though there will probably be a new option to download our own patched version of Widgets.
Note that we won't want to make win\compile.txt verbose, because it is intended for developers, really. It would be nice to have a guide to compiling Audacity on Windows with images and hand-holding for those who would otherwise struggle with it, but we don't really have the resources to do that ourselves.
Permanent link to this post Posted by cmjone » Mon Dec 26, 2016 11:51 pm
Gale:
I have started to work on the instructions. Once I get it done, I will posted it in the forum for you to review. Make changes accordingly. The is one more thing I hope you could help me out. After compilation, I open up the application to look at the Help. It say a local copy is not available. When I open up Audacity/Help from the Windows explorer, it contains a manual folder, in addition to 4 files, audacity.1, audacity.appdata.xml, Makefile.am and Makefile.in. Inside the manual folder, there are 4 other folders, images, m, man and manual and 3 files, favicon.ico, index.html and quick_help.html. In the man folder, there are many files containing help information. I am able to open up the files by clicking them. All of them contains help info. It appears everything is there. However, it appears a link is missing between all these files and the HELP button on the application. I wonder if you could shed some light on this missing Link.
Thanks
cmjone
Permanent link to this post Posted by Gale Andrews » Tue Dec 27, 2016 2:04 pm
cmjone wrote:I have started to work on the instructions.
It would be quicker to just tell us what is wrong or confusing with the current instructions. The developers won't accept long essays in compile.txt.
Or if you are writing a complete step by step with images, you would probably be better to create that on a draft page on our Wiki: http://wiki.audacityteam.org/. I could set up a Wiki account for you.
cmjone wrote:After compilation, I open up the application to look at the Help. It say a local copy is not available. When I open up Audacity/Help from the Windows explorer, it contains a manual folder, in addition to 4 files, audacity.1, audacity.appdata.xml, Makefile.am and Makefile.in. Inside the manual folder, there are 4 other folders, images, m, man and manual and 3 files, favicon.ico, index.html and quick_help.html. In the man folder, there are many files containing help information. I am able to open up the files by clicking them. All of them contains help info. It appears everything is there. However, it appears a link is missing between all these files and the HELP button on the application. I wonder if you could shed some light on this missing Link.
Audacity won't see the Manual there. When you build the "help" project it should copy the "manual" folder to a "help" folder in your build folder (Audacity\win\Release, or Audacity\win\Debug if you built the Debug version of Audacity). When you execute audacity.exe from that build folder, Audacity "should" see the Manual there. It doesn't for me, so I suppose it is a bug.
What you could do is download the latest Inno Unicode Installer from http://www.jrsoftware.org/isdl.php, then run audacity\win\audacity.iss to build the Audacity installer. The installer is placed in audacity\win\Output. Execute the installer, run Audacity from the installed location then it should see the Manual.
Permanent link to this post Posted by cmjone » Tue Dec 27, 2016 9:45 pm
Hi Gale:
I do not expect the my instructions would go to audacity/win/compile.txt. Perhaps it is best to post it elsewhere. If the users do not have some experience, it is better to have the step by step instructions. If you want to, I can email my instructions to you to review once I finish to decide what to do next. At this point, I just supplement what I think it should be included. I am not re-writing everything. What do you think?
I saw the files in both places, in the win/release/help and audacity/help.
I did try it the way you suggested. During the Inno compilation, it said the manual was not there. I then downloaded a copy of the manual and placed it in the help folder. Then I re-compiled with Inno. I got the final product in the output folder. It was installed uneventfully. After I opened up the application, the manual was there.
cmjone
Permanent link to this post Posted by steve » Tue Dec 27, 2016 9:58 pm
cmjone wrote: Perhaps it is best to post it elsewhere.
I'd be interested to see your notes cmjone, and in the new year I 'may' be in a position to try them out (depending on whether my new computer comes with Windows installed or not). When you're ready, I'd suggest that you post them as a new topic in this ("Compiling Audacity") section of the forum and we can take it from there.
Next
Return to Compiling Audacity
Who is online
