filehistory.cpp returning reference to temporary
Building and customizing Audacity from the source code.
Permanent link to this post Posted by henric » Sat May 07, 2016 4:29 am
I'm getting a compiler warning like this:
Code: Select all
src\widgets\filehistory.cpp(92): warning C4172: returning address of local variable or temporary
which is the second return statement in GetHistoryFile():
Code: Select all
const wxString &FileHistory::GetHistoryFile(size_t i) const
   wxASSERT(i < mHistory.GetCount());
   if (i < mHistory.GetCount()) {
      return mHistory[i];
   return wxEmptyString;
where wxEmptyString is:
Code: Select all
extern WXDLLIMPEXP_DATA_BASE(const wxChar*) wxEmptyString;
Since wxEmptyString isn't a wxString, a temporary is constructed and returned by reference. That temporary is destroyed when GetHistoryFile() returns.
This is probably not a good idea.
henric
Re: filehistory.cpp returning reference to temporary
Permanent link to this post Posted by Gale Andrews » Mon May 09, 2016 12:44 pm
Thanks - this does occur in VS2013 so I reported it on audacity-devel: http://audacity.238276.n2.nabble.com/Compiler-warning-in-FileHistory-cpp-td7573891.html.
Permanent link to this post Posted by Paul L » Mon May 09, 2016 1:30 pm
The assertion tells us that we shouldn't ever take that path in the code, but even so there should be some correct defensive code there.
So it chould be changed to
Code: Select all
static const wxString empty;
return empty;
Thanks for the report.
Paul L
Permanent link to this post Posted by Paul L » Mon May 09, 2016 2:40 pm
I pushed a fix. Thank you again for pointing this out.
PRL
Paul L
Return to Compiling Audacity
Who is online
Users browsing this forum: No registered users and 2 guests
