Windows 10 - ASIO - Works on Windows 7 not Windows 10
Building and customizing Audacity from the source code.
Permanent link to this post Posted by bitva » Wed Apr 13, 2016 10:39 pm
Hi! I'm running Windows 10. I compiled Audacity 2.1.2 with ASIO support. It compiled successfully as if I run it on a Windows 7 box, Audacity opens right up (with ASIO support)
If I run it on the Windows 10 box, that I compiled it on, the splashscreen comes up and then closes without a trace.
I ran some procmon.exe while starting it on the Win10 box and it seems to hit Audiodg before cleanly exiting threads and then itself. Nothing obvious in the procmon output but I do need to dig into that a bit deeper.
If I install Audacity 2.1.2 from the packaged binary / executable you provide, that one starts up fine (though obviously no ASIO support which I need).
Before I get into further procmon hell though, any ideas on where else I might look? I'm wondering if I need to try code from the 2.1.3 branch instead?
Not sure if this is a compile issue or a Windows issue but trying this section first :)
Thanks for your time!
-Matt
bitva
Re: Windows 10 - ASIO - Works on Windows 7 not Windows 10
Permanent link to this post Posted by Gale Andrews » Thu Apr 14, 2016 11:42 am
2.1.3-alpha (latest code) uses a later PortAudio version. It may be worth trying for that reason, but no other changes we've made since 2.1.2 are likely to be relevant.
Why do you need ASIO support - for multi-channel recording or for a specific audio device? Can you post Help > Audio Device Info... so we can see your devices, or tell us what they are? If you are using external audio devices, do they have correct Windows 10 drivers and firmware supplied by their manufacturer, and have you tried disconnecting the devices to see if that makes a difference?
If you use Windows WASAPI host in 2.1.2, latencies should not too bad, especially in Windows 10.
Audacity 2.0.4 (http://www.oldfoss.com/Audacity.html) supported Windows WDM-KS which performs almost as well as ASIO but there is a chance that support will crash your computer. We dropped WDM-KS because of those crashes.
Permanent link to this post Posted by bitva » Thu Apr 14, 2016 4:40 pm
I need ASIO support for both multi-channel and a specific device: Tascam US-1800. Using Audacity 2.1.2 compiled with ASIO driver and it works perfectly in Windows 7 (recording our band with it all :)
With our without the Tascam connected, in Windows 10, ASIO-compiled Audacity will not open.
I'll keep playing around and will report back with anything useful!
Thanks for all you do here!
-Matt
bitva
Permanent link to this post Posted by bitva » Thu Apr 14, 2016 11:04 pm
UPDATE
If I compile without ASIO on Windows 10 - everything is fine.
Question:
Do I have to use the Steinberg ASIO driver? Would asio4all work? I'll give it a whirl
bitva
Permanent link to this post Posted by Gale Andrews » Fri Apr 15, 2016 12:18 pm
bitva wrote:If I compile without ASIO on Windows 10 - everything is fine.
I would expect that given you said the pre-compiled 2.1.2 launches on Windows 10.
bitva wrote:Do I have to use the Steinberg ASIO driver? Would asio4all work?
To use an ASIO4ALL driver, Audacity must still be compiled with ASIO support.
I don't know if ASIO4ALL will solve the problem that Audacity doesn't launch. That "could" be some other problem, like a security app interfering. Have you installed a third-party anti-virus?
ASIO4ALL won't give you the low latencies that ASIO will.
You could also try compiling the latest HEAD development code: https://github.com/audacity/audacity/archive/master.zip but that will only help if the later PortAudio version somehow helps.
Permanent link to this post Posted by bitva » Fri Apr 15, 2016 5:45 pm
Okay, I can run ASIO compiled Audacity if I stop the "Windows Audio" service (Audiosrv). It runs and obviously only has the ASIO device(s) available...which is fine for my needs as the Tascam is both recording and playback device.
Interesting eh?
bitva
Permanent link to this post Posted by Gale Andrews » Sat Apr 16, 2016 2:03 pm
bitva wrote:Okay, I can run ASIO compiled Audacity if I stop the "Windows Audio" service (Audiosrv). It runs and obviously only has the ASIO device(s) available...which is fine for my needs as the Tascam is both recording and playback device.
Is this in 2.1.2 or 2.1.3-alpha?
It's possible 2.1.3-alpha will run without the Windows Audio service turned off.
Permanent link to this post Posted by Revleo » Thu Feb 09, 2017 4:08 pm
Hello anyone,
Our church records its services for broadcast on a local radio station. Currently using Audacity but need to go to multi-track (at least 4) for a better mix. I am not a computer programmer and don't understand what the "compile ASIO" stuff is about. We have a nice Soundcraft Multi-track board (12 channels) but the drivers do not allow any more than the 2 channels on Audacity. I tried Reaper which gives me all the tracks I need but is too complex for the avg church volunteer to operate. Does anyone have any ideas? Thank you. Direct replies welcome.
Revleo
Permanent link to this post Posted by Gale Andrews » Fri Feb 10, 2017 3:58 pm
You can try changing Audio Host in Device Toolbar to Windows WASAPI or you could try Windows WDM-KS host in Audacity 2.0.4. Please note 2.0.4 might crash your computer if any audio devices on your computer do not support WDM-KS. Explore all the recording device options in Device Toolbar. There may be a "multi" device or similar name that records all the channels.
Otherwise you must use a DAW that supports ASIO or compile Audacity with ASIO support. You must not distribute that ASIO build to anyone else. Perhaps the IT Manager at your church could help you?
Revleo wrote:Our church records its services for broadcast on a local radio station. Currently using Audacity but need to go to multi-track (at least 4) for a better mix. I am not a computer programmer and don't understand what the "compile ASIO" stuff is about. We have a nice Soundcraft Multi-track board (12 channels) but the drivers do not allow any more than the 2 channels on Audacity. I tried Reaper which gives me all the tracks I need but is too complex for the avg church volunteer to operate. Does anyone have any ideas? Thank you. Direct replies welcome.
Return to Compiling Audacity
Who is online
