Hi All,
I tried to compile Audacity on Oracle Linux 6 x86_64. Mayby, it’s a bit unusual, but I have lots of audio tools installed: linuxsampler, LADSPA, LV2 plugins, JACK, etc I used Audacity 2.0.5 until now installed from linuxtech repo. So, I tried to compile the newest version.
I successfully installed wxWidgets-3.0.2 and “devel” rpms of all required libraries. Also I executed ldconfig and, during several unsuccessful compilation attemmpts, I even provided PKG_CONFIG_PATH=/usr/local/lib/pkgconfig/ for ./configure/
Still I’ve got this error:
g++ -DHAVE_CONFIG_H -I. -Wno-deprecated-declarations -D__STDC_CONSTANT_MACROS -DLIBDIR=\"/usr/local//lib\" -I../lib-src/portaudio-v19/include -I../lib-src/lib-widget-extra -I/usr/local/lib/wx/include/gtk2-unicode-3.0 -I/usr/local/include/wx-3.0 -D_FILE_OFFSET_BITS=64 -DWXUSINGDLL -D__WXGTK__ -pthread -I/usr/include -I/usr/include -I../lib-src/libnyquist -I/usr/include/soundtouch -I../lib-src/lv2/include -I../lib-src/lv2/include -I../lib-src/portsmf -I../lib-src/sbsms/include -I../lib-src/libvamp -I/usr/local/lib/wx/include/gtk2-unicode-3.0 -I/usr/local/include/wx-3.0 -D_FILE_OFFSET_BITS=64 -DWXUSINGDLL -D__WXGTK__ -pthread -pthread -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/libpng12 -Wno-unused-local-typedefs -I../lib-src/portmixer/include -DwxDEBUG_LEVEL=0 -Wall -I../include -I../lib-src/FileDialog -MT export/audacity-ExportPCM.o -MD -MP -MF export/.deps/audacity-ExportPCM.Tpo -c -o export/audacity-ExportPCM.o `test -f 'export/ExportPCM.cpp' || echo './'`export/ExportPCM.cpp
export/ExportPCM.cpp: In constructor ‘ExportPCMOptions::ExportPCMOptions(wxWindow*, int)’:
export/ExportPCM.cpp:135: warning: comparison between signed and unsigned integer expressions
export/ExportPCM.cpp: In member function ‘virtual int ExportPCM::Export(AudacityProject*, int, wxString, bool, double, double, MixerSpec*, Tags*, int)’:
export/ExportPCM.cpp:401: warning: comparison between signed and unsigned integer expressions
export/ExportPCM.cpp: In member function ‘bool ExportPCM::AddStrings(AudacityProject*, SNDFILE*, Tags*, int)’:
export/ExportPCM.cpp:708: error: ‘SF_STR_GENRE’ was not declared in this scope
export/ExportPCM.cpp:732: error: ‘SF_STR_TRACKNUMBER’ was not declared in this scope
export/ExportPCM.cpp: In member function ‘virtual wxWindow* ExportPCM::OptionsCreate(wxWindow*, int)’:
export/ExportPCM.cpp:877: warning: comparison between signed and unsigned integer expressions
At global scope:
cc1plus: warning: unrecognized command line option "-Wno-unused-local-typedefs"
make[2]: *** [export/audacity-ExportPCM.o] Error 1
make[2]: Leaving directory `/home/igor/Music/Tools/audacity212/audacity-minsrc-2.1.2/src'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/igor/Music/Tools/audacity212/audacity-minsrc-2.1.2/src'
make: *** [all-recursive] Error 1
Now, trying compiling from Git
