SVN Checkout
Building and customizing Audacity from the source code.
SVN Checkout
Permanent link to this post Posted by Apesbrain » Sun Jul 19, 2015 1:02 am
When using TortoiseSVN Checkout, what is the correct "URL of repository" in order to download just the 2.1.1 release code?
Apesbrain
Operating System: Windows 7
Re: SVN Checkout
Permanent link to this post Posted by steve » Sun Jul 19, 2015 1:13 am
Audacity has moved to GitHub
https://github.com/audacity/audacity
Re: SVN Checkout
Permanent link to this post Posted by Apesbrain » Sun Jul 19, 2015 2:51 am
That URL causes a number of older versions to download as well. I just want the source code for the current release.
When I compiled 2.1.0 with ASIO I did so on Win 7 with VS Express 2013, wxWidgets 2.8.12, and Python34. I've now tried twice to compile 2.1.1 in exactly the same way and it failed both times: once using the "trunk" code and a second time using the "tags" code. What is different about compiling this new release on Windows?
Apesbrain
Re: SVN Checkout
Permanent link to this post Posted by steve » Sun Jul 19, 2015 9:37 am
Apesbrain wrote:That URL causes a number of older versions to download as well. I just want the source code for the current release.
Just go to the GitHub address in your web browser. https://github.com/audacity/audacity
There is a dowload link for the current source code in the right hand column.
The current ZIP file is virtually identical to the 2.1.1 release except that the version number has been changed to 2.1.2 alpha, and there have been 2 bug fixes since the 2.1.1 release.
I don't use Windows so I can't help you with compiling on Windows. The "readme" instructions included in the code "should" be correct.
Re: SVN Checkout
Permanent link to this post Posted by Apesbrain » Sun Jul 19, 2015 3:53 pm
steve wrote:The current ZIP file is virtually identical to the 2.1.1 release except that the version number has been changed to 2.1.2 alpha, and there have been 2 bug fixes since the 2.1.1 release.
Thanks for your reply. I have gotten this "2.1.2-alpha" version to compile with errors only on "Help" and "Locale" which do not seem critical.
Is there no way to checkout the final 2.1.1 release code? I'd like to end up with the 2.1.1 release version with ASIO which I need for my USB audio interface.
Apesbrain
Re: SVN Checkout
Permanent link to this post Posted by steve » Sun Jul 19, 2015 8:15 pm
Apesbrain wrote:Is there no way to checkout the final 2.1.1 release code?
Yes there is, but I'll need to look it up.....
Re: SVN Checkout
Permanent link to this post Posted by steve » Sun Jul 19, 2015 8:20 pm
Re: SVN Checkout
Permanent link to this post Posted by Apesbrain » Sun Jul 19, 2015 10:06 pm
Thanks!
Apesbrain
Re: SVN Checkout
Permanent link to this post Posted by Apesbrain » Wed Mar 22, 2017 12:26 am
Is there a new source code repository? Where would I point to "SVN checkout" the 2.1.3 release version source? I'd like to build ASIO version.
I tried pointing to <https://github.com/audacity/audacity> but it can't be right as it is too large and after 900MB failed. Thanks.
Apesbrain
Re: SVN Checkout
Permanent link to this post Posted by steve » Wed Mar 22, 2017 8:38 am
Audacity development source code is on GitHub:
For a one-off download, click on the "Clone or Download" button on the right side of the page, then select the "Download Zip" option. The file size is 26.3 MB.
For developers that want to be able to keep up to date with the current code it is better to clone the source code repository.
Release version source code is available from this page:
https://github.com/audacity/audacity/releases
Windows users will usually want the most recent (2.1.3) Zip version (28.4 MB)
For Linux, there is a "mini" tarball (7.7 MB) available from the link at the top of this page on the Audacity website: http://www.audacityteam.org/download/source/
Shared libraries that are usually installed as standard on Linux Desktop systems have been removed so as to reduce the download size.
See also this page and pages that it links to: http://www.audacityteam.org/download/source/
Next
Return to Compiling Audacity
Who is online
