My system is CENTOS 6.6
I typed:
./configure --enable-unicode=no
That worked fine. Then I typed:
./make
That ran for a good while, and then resulted in the following error message:
g++ -DHAVE_CONFIG_H -I. -D__STDC_CONSTANT_MACROS -DLIBDIR=“/usr/local//lib” -I…/lib-src/portaudio-v19/include -I…/lib-src/lib-widget-extra -I/usr/local/lib/wx/include/x11univ-ansi-release-2.8 -I/usr/local/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXUNIVERSAL__ -D__WXX11__ -pthread -I…/lib-src/ffmpeg -I…/lib-src/lame -I…/lib-src/libnyquist -I/usr/include/soundtouch -I…/lib-src/libsoxr/src -I…/lib-src/lv2/include -I…/lib-src/portsmf -I…/lib-src/sbsms/include -Wall -Wno-unused-local-typedefs -I…/lib-src/portmixer/include -Wall -I…/lib-src/FileDialog -MT export/audacity-ExportPCM.o -MD -MP -MF export/.deps/audacity-ExportPCM.Tpo -c -o export/audacity-ExportPCM.o test -f 'export/ExportPCM.cpp' || echo './'
export/ExportPCM.cpp: In member function ‘bool ExportPCM::AddStrings(AudacityProject*, SNDFILE*, Tags*, int)’:
export/ExportPCM.cpp:740: error: ‘SF_STR_GENRE’ was not declared in this scope
export/ExportPCM.cpp:764: error: ‘SF_STR_TRACKNUMBER’ was not declared in this scope
At global scope:
cc1plus: warning: unrecognized command line option “-Wno-unused-local-typedefs”
make[2]: *** [export/audacity-ExportPCM.o] Error 1
make[2]: Leaving directory /tmp/audacity-src-2.0.6/src' make[1]: *** [all] Error 2 make[1]: Leaving directory
/tmp/audacity-src-2.0.6/src’
make: *** [all-recursive] Error 1
I commented out the offending lines in the export/ExportPCM.cpp file and tried again:
./make
This yielded a different error:
g++ -DHAVE_CONFIG_H -I. -D__STDC_CONSTANT_MACROS -DLIBDIR=“/usr/local//lib” -I…/lib-src/portaudio-v19/include -I…/lib-src/lib-widget-extra -I/usr/local/lib/wx/include/x11univ-ansi-release-2.8 -I/usr/local/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXUNIVERSAL__ -D__WXX11__ -pthread -I…/lib-src/ffmpeg -I…/lib-src/lame -I…/lib-src/libnyquist -I/usr/include/soundtouch -I…/lib-src/libsoxr/src -I…/lib-src/lv2/include -I…/lib-src/portsmf -I…/lib-src/sbsms/include -Wall “” -I…/lib-src/portmixer/include -Wall -I…/lib-src/FileDialog -MT export/audacity-ExportPCM.o -MD -MP -MF export/.deps/audacity-ExportPCM.Tpo -c -o export/audacity-ExportPCM.o test -f 'export/ExportPCM.cpp' || echo './'
g++: : No such file or directory
At this point I’m stuck. Can someone suggest what I might try to get this build to succeed.
thanks - Gary Krohmer
