Here is the error
- Code: Select all
ketan@ubuntu:~/Programming/Audacity_Source/audacity-src-1.3.11-beta$ make
make -C lib-src
make[1]: Entering directory `/home/ketan/Programming/Audacity_Source/audacity-src-1.3.11-beta/lib-src'
make -C FileDialog
make[2]: Entering directory `/home/ketan/Programming/Audacity_Source/audacity-src-1.3.11-beta/lib-src/FileDialog'
g++ -c -g -O2 -I. -I/usr/local/lib/wx/include/gtk2-ansi-release-2.8 -I/usr/local/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXGTK__ -pthread -D_REENTRANT -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include FileDialog.cpp -o FileDialog.o
In file included from FileDialog.cpp:17:
FileDialog.h:24:21: error: wx/defs.h: No such file or directory
FileDialog.h:25:24: error: wx/filedlg.h: No such file or directory
In file included from FileDialog.h:34,
gtk/FileDialogPrivate.h:17:33: error: wx/generic/filedlgg.h: No such file or directory
gtk/FileDialogPrivate.h:24: error: expected class-name before ‘{’ token
gtk/FileDialogPrivate.h:28: error: expected ‘)’ before ‘*’ token
gtk/FileDialogPrivate.h:38: error: ‘wxString’ does not name a type
gtk/FileDialogPrivate.h:39: error: ‘wxArrayString’ has not been declared
gtk/FileDialogPrivate.h:40: error: ‘wxString’ does not name a type
gtk/FileDialogPrivate.h:41: error: ‘wxString’ does not name a type
gtk/FileDialogPrivate.h:42: error: ‘wxArrayString’ has not been declared
gtk/FileDialogPrivate.h:45: error: ISO C++ forbids declaration of ‘wxString’ with no type
gtk/FileDialogPrivate.h:45: error: expected ‘,’ or ‘...’ before ‘&’ token
gtk/FileDialogPrivate.h:46: error: ISO C++ forbids declaration of ‘wxString’ with no type
gtk/FileDialogPrivate.h:46: error: expected ‘,’ or ‘...’ before ‘&’ token
gtk/FileDialogPrivate.h:47: error: ISO C++ forbids declaration of ‘wxString’ with no type
gtk/FileDialogPrivate.h:47: error: expected ‘,’ or ‘...’ before ‘&’ token
gtk/FileDialogPrivate.h:48: error: ISO C++ forbids declaration of ‘wxString’ with no type
gtk/FileDialogPrivate.h:48: error: expected ‘,’ or ‘...’ before ‘&’ token
gtk/FileDialogPrivate.h:49: error: ISO C++ forbids declaration of ‘wxString’ with no type
gtk/FileDialogPrivate.h:49: error: expected ‘,’ or ‘...’ before ‘&’ token
gtk/FileDialogPrivate.h:64: error: ‘wxString’ has not been declared
gtk/FileDialogPrivate.h:68: error: ISO C++ forbids declaration of ‘DECLARE_DYNAMIC_CLASS’ with no type
gtk/FileDialogPrivate.h:69: error: expected ‘;’ before ‘DECLARE_EVENT_TABLE’
gtk/FileDialogPrivate.h:72: error: ‘wxString’ does not name a type
gtk/FileDialogPrivate.h:62: error: ‘wxSIZE_AUTO’ was not declared in this scope
FileDialog.h:57: error: ‘wxString’ does not name a type
FileDialog.cpp:19: error: variable or field ‘EnableButton’ declared void
FileDialog.cpp:19: error: ‘wxString’ was not declared in this scope
FileDialog.cpp:19: error: expected primary-expression before ‘cb’
FileDialog.cpp:19: error: expected primary-expression before ‘void’
FileDialog.cpp:52: error: ‘wxString’ does not name a type
make[2]: *** [FileDialog.o] Error 1
make[2]: Leaving directory `/home/ketan/Programming/Audacity_Source/audacity-src-1.3.11-beta/lib-src/FileDialog'
make[1]: *** [FileDialog-recursive] Error 2
make[1]: Leaving directory `/home/ketan/Programming/Audacity_Source/audacity-src-1.3.11-beta/lib-src'
make: *** [audacity] Error 2
Any suggestions on how to fix this error, or check to check if the problem is due to wxWidgets?
Ketan
