Changing recording device produces an error on recording
Help for users of Audacity 1.3.x (Beta) on GNU/Linux and other Unix-like operating systems.
Postby ankle » Thu Aug 28, 2008 12:30 am
I'm using Audacity 1.3.5 in Ubuntu Hardy, and have found a bug in the recording device selection.
If I open Audacity, then in the Audio I/O preferences set the Recording Device to "OSS: /dev/dsp1", press OK and start recording, everything's fine.
If I first set the Recording Device to a different device, try recording (which produces no signal, obviously), then go back to the Audio I/O preferences and set the Recording Device to "OSS: /dev/dsp1", starting to record will produce an error:
"Error while opening sound device. Please check the input device settings and the project sample rate."
On restarting Audacity, when the Recording Device is now set to "OSS: /dev/dsp1" by default, recording works fine with no errors.
It took a while to work out that the recording device was actually working, but it was Audacity (or perhaps some other part of the audio system, I'm not sure) producing the error.
ankle
Re: Changing recording device produces an error on recording
Postby stevethefiddle » Wed Sep 03, 2008 2:53 pm
As you point out, setting Audacity to use the incorrect device will not work. However, when you change the device setting, you should restart Audacity so that the change takes effect correctly. This is not really a "bug", it's just that Audacity can not implement all preference changes "on the fly", so certain changes (such as changing the audio device) should be followed by a restart of Audacity.
* * * * * Tips * * * * * Tutorials * * * * * 1.3 Quick Start Guide * * * * * Audacity 1.3 Manual * * * * * Audacity wiki * * * * *
stevethefiddle
Postby ankle » Thu Sep 04, 2008 10:21 pm
Ok, that's fair enough. Maybe display a warning when the preference is changed, saying that a restart is required, so that users know what's going on?
ankle
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 2 guests
