IKhider wrote:The settings that worked for me was placing both i/o settings onto "Asla default".
IKhider wrote:However, under "audio device info" I get a blank field. No information whatsoever, no checklist. Is that normal?
IKhider wrote:A friend suggested I use a walkman instead of a component cassette deck lined through an amp because the line out volume cannot be controlled.
stevethefiddle wrote:Usually you should set the recording device and playback device to ALSA(default)
This is set in "Edit > Preferences > Audio I/O"
Return to GNU/Linux and Unix-like
Users browsing this forum: No registered users and 4 guests
