File menu missing
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
File menu missing
Permanent link to this post Posted by daviddoria » Tue Jun 15, 2010 8:10 pm
I am using audacity that ships with Fedora 13. I noticed that the file menu is missing! (I have all of the toolbars/buttons at the top of the window, but no menus). Anyone know how to fix this?
Thanks,
David
daviddoria
Re: File menu missing
Permanent link to this post Posted by bgravato » Tue Jun 15, 2010 10:37 pm
Is it only the File menu? or all the other menus (edit, view, effects, etc) too?
What version of audacity is it? What window manager are you running? gnome? kde? some other?
If you press Alt-F anything happens? (this should bring down the file menu...)
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
bgravato
Permanent link to this post Posted by Gale Andrews » Tue Jun 15, 2010 10:41 pm
daviddoria wrote:I am using audacity that ships with Fedora 13. I noticed that the file menu is missing! (I have all of the toolbars/buttons at the top of the window, but no menus). Anyone know how to fix this?
Please post an image of the entire screen if what bgravato wrote does not help. Some possibilities: the top of Audacity is hidden under a top-aligned taskbar; the Audacity Device Toolbar is obscuring the Menu bar...
Permanent link to this post Posted by daviddoria » Thu Jun 17, 2010 12:14 pm
It is the whole menu bar that is missing. I can't tell which version of audacity it is because I don't have a help menu! I am running gnome. When I press Alt-F nothing happens.
Here is a screenshot:
http://rpi.edu/~doriad/Screenshot.png
Thanks for your help so far.
Dave
daviddoria
Permanent link to this post Posted by bgravato » Thu Jun 17, 2010 2:09 pm
Apparently that's caused by gnome's globalmenu applet. I guess this is an attempt of creating in gnome the macos-x behaviour, but apparently not very successfully...
Anyway I found this blog post which might help you:
http://mamchenkov.net/wordpress/2010/05 ... lications/
bgravato
Permanent link to this post Posted by daviddoria » Thu Jun 17, 2010 2:19 pm
Hm, I actually had tried that, but then audacity complained that
Code: Select all
[[email protected] ~]$ audacity&
[1] 2975
[[email protected] ~]$ Gtk-Message: Failed to load module "globalmenu-gnome": libglobalmenu-gnome.so: cannot open shared object file: No such file or directory
Expression 'stream->capture.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 3653
and wouldn't start.
However, this time, it still produces that error, but now it seems to be working fine!
Strange... but working.
Thanks again!
Dave
daviddoria
Permanent link to this post Posted by bgravato » Thu Jun 17, 2010 2:29 pm
After uninstalling the globalmenu did you restart gnome?
Also sometimes audacity fails to start when some conditions saved in the preferences file from previous session fail, such as missing device, which is not the case here... nonetheless it could help to delete the preferences file (~/.audacity-data/audacity.cfg) and start audacity with all preferences reset to default...
bgravato
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 2 guests
