recording plays slower than should be
Help for users of Audacity 1.3.x (Beta) on GNU/Linux and other Unix-like operating systems.
Permanent link to this post Posted by haussler » Wed Oct 07, 2009 5:06 pm
hello,
Im trying to record audio from a websites integrated player to my HD. it sounds fine streamed through the player but once its recorded with Audacity, the file plays about 10% slower than normal. I can speed it up by going into 'effect/change speed' on the toolbar, but I just wondered why that might happen?
info:
Audacity 1.3.7 (soundtouch uninstalled as it really screwed everything up).
slackware 12.2
playback device = ALSA default
recording device = hw:0,0 (my soundcard)
as far as Im aware, all other options are the same as when installed. CPU and memory seem ok, not maxed.
haussler
Re: recording plays slower than should be
Permanent link to this post Posted by Gale Andrews » Thu Oct 08, 2009 1:30 am
haussler wrote:hello,
info:
slackware 12.2
Try using a project rate in Audacity that is the same as a rate supported by your sound card. Report to Slackware if problems persist because they supplied the Audacity package, not us (the current Audacity released code is at 1.3.9). If you are not already doing so, stick to recording only one or two channels.
Permanent link to this post Posted by haussler » Mon Oct 12, 2009 3:14 pm
Gale, just to let you know that I reinstalled a stock Slackware 12.2, and Audacity now works perfectly :D
I think it was the soundtouch package that I had downloaded which was the problem the first time around.
I have now recorded and edited the audio that I need, so thanks very much to you Gale, and to the other Audacity devs for this useful software.
haussler
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 3 guests
