Cannot find exported .wav and .mp3 files in Finder.
Permanent link to this post Posted by hakonwikstrom » Thu Dec 27, 2012 9:58 am
Using Audacity 1.3.13-beta, I accidently exported wav and mp3 files to a default folder, also containing the .xml files with metadata and a folder named Autosave. I cannot find this default folder in MacOS X Finder, neither by navigating the folders nor by searching for them. Where are my files? I see them when trying to export a new file, but not in Finder.
hakonwikstrom
Re: Cannot find exported .wav and .mp3 files in Finder.
Permanent link to this post Posted by kozikowski » Thu Dec 27, 2012 3:29 pm
If you're on Snow Leopard, the Library folder is hidden. I think you can get there from the Go menus.
Go > Go To Folder > /Users/koz/Library
Put your user name in there instead of koz.
That should give you a listing containing Application Support and inside that audacity.
Permanent link to this post Posted by hakonwikstrom » Thu Dec 27, 2012 5:13 pm
Thanks Koz
I found my files this way :)
I'm fairly new to OSX so I find it strange not being able to show hidden folders and files; I tried to find this first but without success.
Hakon
hakonwikstrom
Return to Mac OS X
Who is online
